Gas spraying out at pump auto-shutoff - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 03-10-2010, 03:15 PM
dbtx dbtx is offline
dbtx is starting off with a positive reputation.
Our Expy recently developed the most bizarre of problems. The last 3 full tank fillups at 3 different stations, when the pump automatically shut off, gas sprayed past the pump's seal boot. Not just a little, but a HUGE amount. It probably sprayed out at least 2 feet away from the truck, it was under a lot of pressure. I would have been soaked if I was standing close. I totally forgot to bring this up while at the dealer having tranny work performed. Grrrr.
Anyway, has anybody heard of this problem before? Is it a blocked vent or return line? We have had issues with mice stealing dog food and hiding it in other places in the garage, so I'm suspecting that's what's going here - a blocked vent full of dog food! The stupid animal probably stuffed an entire pound of dog food in between the hood blanket and the hood on my f150. When I popped it open to change my oil, dog food poured out of the hood for a good 10-15 seconds. It was quite comical.
Thanks for any help you guys can give!
Old 03-13-2010, 02:34 PM
poppie poppie is offline
poppie is starting off with a positive reputation.
......................better getya some CAT'S and keep them on the hungry side
Old 03-22-2010, 07:39 AM
Matt In Detroit's Avatar
Matt In Detroit Matt In Detroit is offline
Matt In Detroit is starting off with a positive reputation.
This exact thing happened to me last night when filling my 07 EB EL up from almost empty. Man did it gush when the pumps auto shutoff happened! It was gushing and spraying out at least 2 feet from the truck. 3ft diameter puddle on the ground. Good thing i was up by the front door talking to the kids through the window..
Old 03-22-2010, 10:46 AM
Hmm, well, I'm sorry it happened to you to, but I don't feel so bad now. I felt like an idiot the first few times this happened. Now, I just go the the slowest fill rate the pump will allow when I get within a couple of gallons of when I think it's going to click off. That seems to solve it most of the time.
Old 03-31-2011, 10:54 AM
SickPup404 SickPup404 is offline
SickPup404 is starting off with a positive reputation.
I'm in the same boat. Anyone have any new info? I'm using the same "solution" by just slowing down the flow when it's close, or pushing the nozzle in hard to make a better seal - it still overflows , but usually will run down inside the panel and drain at the rear tire.
Old 04-04-2011, 10:52 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
I have had this happen on my Porsche. Twice now I have had the nozzle eject itself from the car, spray gas on the car, and landing on the ground. I think it has to do with these new vapor nozzels. They SUCK!!
Old 04-05-2011, 04:47 PM
Selkirk Selkirk is offline
Selkirk is starting off with a positive reputation.
Did the same on my 99 the other day, soaked my leg with gas. What a pain.
Old 04-11-2011, 03:13 PM
jake00's Avatar
jake00 jake00 is offline
FTE is my crack
jake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant futurejake00 has a brilliant future
My wife has had it happen while filling our durango, but never the expy
Foul smell from floor vents tombob Ranger & B-Series 3 11-30-2013 11:31 AM
Linear Programming Problem is300wrx General NON-Automotive Conversation 0 04-18-2007 01:16 AM
2004 F150 Brix92 2004 - 2008 F150 2 12-10-2004 03:57 PM
A good dog, a good story. wezol5484 General NON-Automotive Conversation 10 11-26-2004 11:39 AM
Gas Filler 75F250Colorado 1973 - 1979 F-100 & Larger F-Series Trucks 1 03-05-2003 09:21 AM
Tags
2007, automatic, autoshut, f150, filling, ford, gas, gasoline, problems, pump, regulatioin, safety, shut, shutoff, spray, truck, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
