Please Read: 2004 Ford F150 Cam Phaser / VCT Solenoid / Sludge? - Page 2 - Ford Truck Enthusiasts Forums
Old 03-10-2010, 11:00 PM
tommy75703 tommy75703 is offline
tommy75703 is starting off with a positive reputation.
2 more good things to know and live by!
RTFM = Read the Ford Manual
KISS = Keep it simple stupid
Old 03-10-2010, 11:08 PM
Djack04F150XL Djack04F150XL is offline
Djack04F150XL is starting off with a positive reputation.
If you drive that short of trips you should change your oil @ 3k for insurance purposes. PM is less expensive than repair. Also use the FL-820S Motorcraft oil filter and Motorcraft 5w-20 synthetic blend oil. You can't beat the price and quality.
Old 03-10-2010, 11:16 PM
Bought 2 of those filters and 14 quart of that oil today to keep in the garage. I wont take it back there bad enough i got to buy the parts there. In fact a funny story today when this happen and i was changing that soleniod i fould 4 or 5 valve cover bolt that were not even hand tight so i asked them to fix it while i was in there trying to get my 2200 back! They wanted to pull it to the back and i said get the guy and the socket and have him come fix it here infront of me! That how much distrust i have right now! Thanks for the input!
Old 03-10-2010, 11:32 PM
You can buy the oil and filters at Wal-Mart and most auto parts chain stores. I have seen the Motorcraft 5w-20 Full synthetic oil at Advance Auto for about $5/qt., also.
Old 03-11-2010, 12:55 AM
SMok SMok is offline
SMok is starting off with a positive reputation.
The first thing they should have done is check base engine oil pressure. Low oil pressure will cause the code p0022. If you have low oil pressure, the vct system will not work properly. All the other codes are because the vct system isn't working properly. The base oil pressure has to be more then 25psi, when HOT. This is key. When the oil gets hot, it thins out causing lower oil pressure.
Old 03-11-2010, 08:36 AM
EBTDM EBTDM is offline
EBTDM is starting off with a positive reputation.
Start by writing one very well detailed letter of complaint to the dealership with all the CC listed at the salutations. Include at least your Tyler, Tx. Chamber of Commerce, BBB, Ford Motor Co. corporate customer service. This along with the follow on documentation is what you want to have in hand when you go to court. This will be your proof of your efforts and involvement in correcting the bad service you received. Also itemize all your time involved. Others may be able to offer opinions on other organizations you may want to include on the CC list; i.e. a local news media advocate.
Regarding the sludge in your engine, I have seen a lot worse on engines with less the 100k miles.
Old 03-11-2010, 01:30 PM
mercman86's Avatar
mercman86 mercman86 is offline
mercman86 is gaining momentum as a positive member of FTE.
Tommy:
Sorry to hear about your problems, but its good to hear that you were able to take care of what should of been an easy fix for that shop. I hope the owners and managers of that place make good on their mistakes and hopefully you'll come out ahead!
Good Luck!
Old 03-15-2010, 01:19 PM
I have good news the dealership just refunded the entire $2200, and gave me a huge im sorry! It good to know they stand behind there work and people!
Old 03-15-2010, 01:44 PM
It is good to know that your problem is solved, both with the truck and with the dealership charges.
Did you go in with documentation and threats in hand ready to present your case or did they realize their errors and just apologize up front?
Old 03-15-2010, 06:57 PM
bridge's Avatar
bridge bridge is offline
bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.bridge has a great reputation on FTE.
Quote:
Wow. Good for you man. What did it take? Just speaking with the service manager?
Old 03-15-2010, 07:37 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
Congrats.....
While we're all quick to jump on dealerships if they make a mistake.....its nice to hear of one thats willing to stand behind their work....
And a plus....you just got yourself a free set of phasers which are known to go bad......bonus
Old 03-15-2010, 09:32 PM
BirdmanStyll BirdmanStyll is offline
BirdmanStyll is starting off with a positive reputation.
Congrats man just read that whole thing, One thing you can't forget is dealerships can't really charge much more then that guy around the corner because it is so competitive out there and well the economy and all. I have a privet mechanic i love an excellent Ford Dealer that is very impressive with quality work. On another note i was told to run ATF transmission fluid for 30 seconds to safely and completely clean your engine.....
  #28
Old 03-16-2010, 01:22 AM
lateb's Avatar
lateb lateb is offline
lateb is starting off with a positive reputation.
Sure glad this all worked out for the best! Concerns me that one photo of your trans dipstick tube is open with what looks like dust down in it. They really should have covered that when removing dirty engine parts. If you've never changed your trans fluid, now might be the time.
  #29
Old 03-16-2010, 08:49 AM
Was a little of both, the documentation I think sealed the deal.
The day after i fixed the truck I put it all together in a two page letter detailing all the facts. On monday I took it to the Director over the service and part separtments and asked him share it with the owner. About an hour later i got a call saying the decided if they had not missed the problem I would have never spent the $2200.
  #30
Old 03-16-2010, 08:55 AM
Quote:
You are right about the dealerships, very competitve prices but once you take your car somewhere you can get stuck in their shop. Its easy to do, just watch out! Adding that I think the only reason this worked out for me is I did take it the dealer, had this been the average shop(smaller ones that could not afford to bleed 2k) I feel no matter the mistakes made they would have stood their ground. i could have got stuck with the bill.
07 EB - "lumpy" idle after phaser lockout install uncleben03 2007 - 2014 Expedition & Navigator 5 01-13-2016 08:09 PM
5.4L PHASERS/VARIABLE VALVE TIMING technical question - Degš. Advance? F150Torqued Modular V8 (4.6L, 5.4L) 0 05-10-2015 01:09 PM
Questions about VCT System - P0012 and P0021 Codes jtillery Expedition & Navigator 6 02-15-2014 02:49 PM
2004 F150: P0012, Rough Idle, Missing at 45mph keltic25 2004 - 2008 F150 3 12-14-2012 09:47 PM
2004 F150 5.4 Cam Phaser Mike(GA) 2004 - 2008 F150 5 05-28-2012 11:24 AM
Tags
2004, 54, 54l, bad, cam, engine, f150, ford, phaser, problems, replace, service, shoot, solenoid, start, ticking, trouble, tyler, vct
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
