Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 03-10-2010, 10:38 AM
tbrowning tbrowning is offline
Garage is empty, add now
tbrowning is starting off with a positive reputation.
1961 unibody
What is the easyest and cheaps way to put power steering on a 61 unibody?
  #2 (permalink)
Old 03-10-2010, 11:09 AM
gritsngumbo's Avatar
gritsngumbo gritsngumbo is offline
1961 Ford F-100
My Garage
gritsngumbo is gaining momentum as a positive member of FTE.
I don't really think there is an "easy" or "cheap" way to add power steering to a straight axle truck. Guess it would depend on the capacity of your wallet.
One solution, which I happen to like and plan to use when budget allows, is the Rack and Pinion setup by No Limit Engineering.
Link: POWER STEERING STRAIGHT AXLE-No Limit Engineering (scroll down under size/color for the 61-64 setup). Cost is $599, plus you will need to buy a power steering pump and either replace steering column or cut your current column off in order to hook up the R&P to the column. (How to instructions are on the site).
Note: If you have a Y-block, you can find PS pumps fairly easily, if you have a 223 I-6, PS pumps are almost impossible to find (unless you can fabricate a bracket).
Others have used a Toyota box but I don't know much about that setup.
You might first try making sure your current front suspension is in good shape (king pins/bushings, tie rod ends, steering box, alignment, etc.) before you make the PS change. You may find that by tweaking the front suspension (which you will need to do to have a good, safe setup with the R&P) you will not need the PS (or maybe not need it as much).
__________________
LITTLE RED: 64 F100 Short Style
BIG RED: 63 F100 Long Uni
BIG “UN: 63 F250 Long Flare
RUBY: 61 F100 CC BBW Long Uni
CRIMSON CREW 63 F100 "Stageway"
"RANGER" 66 F100 CC Long Flatbed
  #3 (permalink)
Old 03-10-2010, 11:29 AM
Thanks That is just what i was looking for
  #4 (permalink)
Old 03-10-2010, 07:22 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Mumert now offers 223 PS brackets..
Everything to put in power steering requires fabrication skills.
Garbz
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
Tags
1961, bed, box, f100, ford, long, truck, unibody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
