power door lock kit - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
power door lock kit
Old 03-10-2010, 11:05 AM
meier63's Avatar
meier63 meier63 is offline
meier63 is gaining momentum as a positive member of FTE.
Question power door lock kit
Hey guys . Have any of you guys ever installed power door locks on your truck. I have a crew cab and iam getting tired of always having to reach around an unlock all the doors for my passengers.( ok its not fatigue, its laziness) Anyway , does anyone know where i might be able to get a kit to do this. It doesnt seem like it wolud be that difficult to do. The difficult part is justifying the extra expense to my wife!
Old 03-10-2010, 11:13 AM
Fishin76's Avatar
Fishin76 Fishin76 is offline
Fishin76 has a good reputation on FTE.Fishin76 has a good reputation on FTE.
Find a CC with PDL's in the JY and take all the door panels switches, wiring, and the locks, and go for it. All bolt in's, the Trick will be to get the GEM to control them so you have Keyless entry>....... But you could easily wire them up manually. Even easier, take the doors with everything in them. You could get PW's as well....
Old 03-10-2010, 08:47 PM
NM04FORD's Avatar
NM04FORD NM04FORD is offline
NM04FORD is starting off with a positive reputation.
My truck had manual door locks also, I had a local audio store install an alarm and door actuators on the front doors only. After getting it home I pulled the front door panel off to see what was involved, super simple. Went back bought 2 more actuators and did the rears in about 2hours just tapped into the wires they ran for the fronts. The actuators are allover the web any where from 5 bucks to 20 bucks they all look the same. Mine is set up to lock if all the doors are closed when the truck starts, and unlock when the ignition is turned off. So to unlock from the inside I have to shut the truck off, but it would be pretty simple to add a switch. So thats an option plus you can sell her on the security of the alarm. These trucks are pretty popular for thieves.
Old 03-11-2010, 08:35 AM
Budman1962's Avatar
Budman1962 Budman1962 is offline
Budman1962 is starting off with a positive reputation.
Old 03-11-2010, 08:50 AM
Fishin76's Avatar
Quote:
Originally Posted by Budman1962 View Post
I don't think this helps him much. Those instructions are for the OEM power locks. He is putting in aftermarkets.
Old 03-11-2010, 01:53 PM
Budman1962's Avatar
The aftermarket ones are identical to the redesigned ford ones. I bought one ford and one aftermarket and you can't tell them apart.
Budman
Old 03-11-2010, 02:07 PM
Fishin76's Avatar
what I mean is NON- OEM style power locks. Like the kind you may get from the local auto customization shop. He doesn't have the OEM locks, wiring, or switches.
Replace all cylinder locks or re-set the tumblers? Dean06919 1987 - 1996 F150 & Larger F-Series Trucks 4 04-30-2016 02:14 PM
Door handle replace? SilentType 1999 - 2003 7.3L Power Stroke Diesel 5 08-13-2014 01:19 PM
Ford Remote Starter installation ? Byron W 2009 - 2014 F150 7 02-18-2014 08:56 AM
Door Lock Help Please.. schlepprock250 1999 - 2003 7.3L Power Stroke Diesel 8 01-13-2014 08:51 PM
How do you remove the door latch assy. from a 56 F100 Aus56 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 09-22-2013 09:00 PM
Tags
2000, actuator, connect, door, f150, f250, ford, installing, kit, kits, lock, locks, power, transit, tricks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
