99' 5.4 rebuild kit - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99' 5.4 rebuild kit
Old 03-09-2010, 10:18 PM
abes250 abes250 is offline
abes250 is starting off with a positive reputation.
99' 5.4 rebuild kit
Well heres the deal, just in the last 4 weeks my 5 4 has been going through the oil. Its not going on the ground. I've heard, what I thought was a lifter, now I think its something bigger. It used to quiet down after it warmed, but now its clacking all the time. I have since parked it and am looking to find a good rebuild kit. If im gunna do this, mite as well amp it up a bit. Does anyone have any leads on what I should do. The truck is gunna live its life pullin racecars to the track and a fifthwheel camper.
Old 03-09-2010, 11:28 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Before yanking the engine out and tearing it down, were you going to do any diagnostic testing to find out of you need a rebuild? At minimum I would start with a compression test and an engine oil analysis. This will tell you the condition if your rings, valve seats and bearings.
The tapping noise may be an exhaust manifold leaking, a cam follower (lifter), or a lot of things that have nothing to do with your loss of oil.
But if you just want to waste money march on, you're heading the right direction.
42 Year Old Bolts - '72 Camper Special Budget Resto apt403 1967 - 1972 F-100 & Larger F-Series Trucks 13 02-01-2014 03:43 PM
Thinking about 429 for my 64 59flatbedford Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 11-01-2010 04:50 PM
MPG Question LRE F150 1997 - 2003 F150 13 03-26-2006 09:14 PM
Whats Ivan gunna break first? Ryan50hrl Offroad & 4x4 49 06-18-2005 11:08 PM
tranny slipping among other things optikal illushun Clutch, Transmission, Differential, Axle & Transfer Case 0 09-30-2003 02:34 PM
Tags
1999, 2002, 250, 54, 99, engine, ford, ki, kit, kits, master, motor, rebuild, rebuilt, rebuld
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
