Gear Ratio in a 77 bronco
Check your door or door post for a placard with an axle code.
You may also get lucky and find the tag on the rear axle, which will be on one of the studs holding the carrier to the housing.
If your speedo is accurate, and you have a tach, we can get close if you give a mph/rpm in top gear or whatever is 1:1 if you have an OD trans, PLUS your tire size.
Novak Conversions - Gearing & Gearing Math for Jeeps
I dont have any problems. I got the registration and I got an antique plate with no questions asked so I'm good to go. My wife is about to take the notary test, so when she does, Ill get her to do the right paperwork to get the vin# right. Then I will save the old title so that if I find another one without a title, problem solved.
SC'79
11-15-2012 12:23 PM
gquinn8516
04-17-2005 09:09 PM
