Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 vanSPONSORED BY:
  #1 (permalink)
Old 03-09-2010, 05:57 PM
superdutyquest superdutyquest is offline
Garage is empty, add now
superdutyquest is starting off with a positive reputation.
EGR delete and OIl Cooler install
Looking at tackling this job really soon,parts are on the way.I was wondering,if the coolant passes through the oil cooler to the EGR cooler and I install an EGR delete and new oil cooler.Does the flow of coolant get interrupted and engine oil overheat?How does that work?
  #2 (permalink)
Old 03-09-2010, 06:12 PM
amdriven2liv's Avatar
amdriven2liv amdriven2liv is offline
2004 Ford F-350
amdriven2liv is a splendid one to beholdamdriven2liv is a splendid one to beholdamdriven2liv is a splendid one to beholdamdriven2liv is a splendid one to beholdamdriven2liv is a splendid one to beholdamdriven2liv is a splendid one to beholdamdriven2liv is a splendid one to behold
Coolant through the oil cooler to the EGR cooler, which your EGR delete should redirect it.
__________________
Sean 1926 Model T Roadster
http://www.ford-trucks.com/forums/picture.php?albumid=5936&pictureid=99192
2004 F350 6.0L CC LB 4x4 King Ranch
Coolant Filter, Cat delete, high idle, PowerMax GT3788VA , heated mirror switch, Duraflaps, Scangauge II, heated seat indicators, Fumoto WIF drain, Fumoto oil drain, blue fuel spring.
  #3 (permalink)
Old 03-09-2010, 06:30 PM
Wow,very informative.Guess that explains it then.Thanks amdriven
  #4 (permalink)
Old 03-09-2010, 06:41 PM
2004 Ford F-350
Your kit should hook up to oil cooler outlet, to the intake inlet, thus bypassing the egr cooler. Which kit did you decide to use?
I should pass this along. Here is the link to the pretty pictures.
Powerstroke 6.0L Technical Intro Manual
I think this was in the tech folder.
__________________
  #5 (permalink)
Old 03-09-2010, 11:35 PM
I went with the Sinister kit.It arrives tomorrow.Thanks for posting all of the useful information.I appreciate it.
  #6 (permalink)
Old 03-10-2010, 12:00 PM
Jax50 Jax50 is offline
Jax50 is starting off with a positive reputation.
Thanks for the diagram flow pictures, I have been trying to picture the flow in my head.
  #7 (permalink)
Old 03-10-2010, 05:10 PM
1_BIGMOFO 1_BIGMOFO is offline
1_BIGMOFO is gaining momentum as a positive member of FTE.
nice pictures!! Thanks
__________________
2004 F250 SD CC 6.0L ARP Studs, HG's, FCD EGR delete, Banks CAI, Intake Elbow, turbo drain upgrade, cooling mod, Fumoto, Full MBRP, SCT X3 - Innovative tunes, 7 ISSPRO gauges, Rough Country lift kit and shocks, Rough Country steering stabilizer, 09 Mirrors, 07 HD headlight conversion, 09 rear bumper, 09 tail lights, HID's, Fresh Paint, Train Horns, Pro-Tech Cab Guard, Weatherguard Box, spray bedliner, wheels and BFG all terrain's...
1971 Nova......
  #8 (permalink)
Old 03-11-2010, 09:10 AM
hndacr hndacr is offline
hndacr is starting off with a positive reputation.
To the OP, speaking from experience, removed the injector harness before removing the intake manifold. If not, you risk breaking the plastic connectors on the injectors. You will be very mad at yourself if you do break them as it adds lots of work to change them out.
__________________
2004 F250 Lariat 6.0 PSD
EGR Delete, Rebuilt Oil Cooler, Dieselsite Coolant Filter, Isspro EV2 EGT, Boost and Trans Temp in A pillar pod. Scangauge showing EOT/ECT. New bushwacker fender flares and paint. Next my kitty might get scared and run away!!
  #9 (permalink)
Old 03-11-2010, 10:58 AM
fgallant's Avatar
fgallant fgallant is offline
fgallant is starting off with a positive reputation.
Here I go as well. I have all the parts I need so far. Should get the Sinister delete kit Moday in the mail. Disconected batts and drained coolant last night. Since I only have from about 5pm till dark I hope to have mine done by Wednesday or so next week. Let ya know how it goes.....
  #10 (permalink)
Old 03-11-2010, 01:19 PM
Be very careful not to drop any nuts or bolts when removing them. If you do, they will tend to hide under the intake manifold. The last thing you want is a small nut falling in the engine while you are trying to remove the intake. Do you have a detailed writeup as to what you need to remove. If not, there is a great step by step list out there I could dig up for you. 2 last tips, you may want to zip tie your belt in place after removing the alternator, this way you wont have to reroute the belt when you are done....also you may want a turkey baster to suck the oil out from under the oil cooler once you pull it. Have rags on hand as pulling that cooler is messy!!! GOOD LUCK...
__________________
  #11 (permalink)
Old 03-11-2010, 01:31 PM
fgallant's Avatar
hndacr,
I have a pretty good write up and have been copy pasting tips on a Word doc from people on this site. I also have been reviewing the Sinister instructions, as this will get most of the "above oil cooler" items off and out of the way. If you can dig up a complete write up I would appreciate it. Either post or PM me. I'm sure I'll be back with questions or concerns as I go along. Thanks to all thus far. Fishing time is rapidly aproaching and I want my truck back!
  #12 (permalink)
Old 03-11-2010, 02:34 PM
Quote:
can you please post up what you have? or PM it to me?
Thanks
__________________
1971 Nova......
  #13 (permalink)
Old 03-11-2010, 02:40 PM
fgallant's Avatar
This is what I have so far. If you go to the Sinister diesel site you can see the directions for install of it.
Tip1 get a freeze plug welded into the exhaust end of that new cooler.
tip2, Don't be lazy ,,Pull the connector off the first two injectors on each side.
tip3 clean the valley AFTER you pull the turbo but BEFORE you pull the
oilcooler, it could save your IPR.
be sure to protect the turbo drain hole in the HPOP. fficeffice" />>>
Getting started
Drain the coolant out of the Radiator, and disconnect the batteries. Then start taking things apart, First remove the front part of the air intake, then the intercooler lines (7/16 deep well socket). Then removed the Degas bottle (10mm socket) after it was out of the way you can get to the 2 bolts that hold the air intake elbow on the turbo in place (8mm socket). Then use a 1/2” drive ratchet in the tensioner pulley to remove the belt, once removed unplug and remove the alternator (13mm socket and 10mm socket).
After that, either drain the
oil or I believe you can just loosen the cap on the oil filter and it will let the oil drain out of the housing. Then take the fuel lines off (11/16 wrench and I used a crescent wrench for the main supply lines) and remove the oil filter/ fuel filter housing. (Either a #40 or 45 hex head socket). Then remove the clamps on both side of the turbo (deep well 7/16 socket) the exhaust manifolds Y pipe clamp on the turbo can be a real pain in the butt!! Just try and stay patient and keep messing with it and it will break loose. Note: if you have aftermarket exhaust it would be easier to completely remove the down pipe. Once the clamps are removed take the 2 bolts out of the oil supply line on top of the turbo (10mm wrench) then take the 3 bolts out of the turbo (10mm socket). There are 2 on the front and one on the back of the turbo, it is on the driver’s side of the turbo and I found it easier to get with a ¼” ratchet reaching around the back of the turbo from the down pipe side. Then its time to remove the turbo, use a pry bar and wiggle it free from the mount. You have to hold your teeth just right and say the perfect combination of 4 letter words but it will wiggle free eventually. Once the turbo is removed take the 4 bolts out of the turbo mount (10mm socket) and remove the mount and turbo oil drain tube.
Now it is time to remove the intake, take the 2 bolts out of the egr
cooler at the front of the intake (deep well 10mm socket) and remove the clamp that holds the egr cooler to the up pipe. I just cut the small blue/orange hose that connects the egr cooler to the oilcooler with a knife. Then loosen all the bolts on top of the intake (10mm socket and wrench) try and keep up with were the bolts that have extra threads sticking up to hold down elec. connections. Note: on the far back right intake bolt there is what I assume to be a ground wire that is held down with a 10mm nut make sure you remember to reinstall it on assembly. There are also 2 bolt the hold the fan shroud to the intake that need to be removed (deep well 15mm socket) and one bolt and clamp holding a fuel line (10mm socket). Remove the intake you might have to tap the Egr cooler out of the bottom of the intake with a hammer. Make sure as you are sliding the intake out that its not caught on any wires or the intake gasket O-rings.>>
Yup, remove your injector harness before pulling the intake manifold. It will make your life much easier and possibly prevent a broken connector. Don't ask how I know this bit of information
  #14 (permalink)
Old 03-11-2010, 02:51 PM
sweet man, thats a great start! I appreciate it. It dosent sound like that bad of a job.
__________________
1971 Nova......
  #15 (permalink)
Old 03-11-2010, 03:03 PM
Mista, that is the same writeup I used.
__________________
Tags
06, 60, 60l, 6l, cooler, f250, ford, intro, manual, oil, powerstroke, rebuild, remove, technical, upgrade
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
