truck keeps dying
Old 03-09-2010, 04:44 PM
Hmann's Avatar
Hmann
Hmann is offline
truck keeps dying
so saturday i rebuilt my carbureator and since then my truck has been dying! It starts strong but after running for about 30sec or when i put in D not R it will start sputtering, and the idle drops way down and it wants to die. But if i give it a bit of gas it will start back up again. Any ideas why its doing this? Idle speed to slow, bad gas?... any ideas?
Old 03-09-2010, 05:05 PM
Furyus1's Avatar
Furyus1
Furyus1 is offline
Just a guess, but have you checked for vacuum leaks?
Old 03-09-2010, 09:06 PM
the 7up guy's Avatar
the 7up guy
the 7up guy is offline
I had that same problem, turned out my plugs were to wide and the timing was off by quite a bit. Sounds great when its just idling but falls flat on its face when its in gear.
Old 03-09-2010, 09:23 PM
4x4 Bart's Avatar
4x4 Bart
4x4 Bart is offline
If it started when you rebuilt the carb, then it is 99% probability it's a problem with the carb.
Vac leaks
float level wrong, check for too high
idle mixture set wrong
idle speed set wrong
Guillaume Koe
03-08-2017 10:01 PM
2wilde4u
1999 to 2016 Super Duty
03-24-2016 10:15 AM
Anthony5050
6.4L Power Stroke Diesel
03-18-2016 09:11 AM
Farris76
12-31-2015 05:42 PM
69 lil' Red Shane
01-24-2014 10:31 AM
Quick Reply: truck keeps dying
