Stripping paint from plastic - Ford Truck Enthusiasts Forums
Old 03-09-2010, 03:49 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
What can I use to strip lacquer from ABS plastic that won't hurt the plastic?
Old 03-09-2010, 07:51 PM
Sand_Man's Avatar
Sand_Man Sand_Man is offline
Sand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud ofSand_Man has much to be proud of
The problem is that anything that chemically removes the paint will also chemically dissolve your plastic. That leaves you with either removing the paint with abrasives (sandpaper) or media blasting You didn't say what the part was so I'm assuming it's an exterior part like a bumper cover for a car. If that's the case and you have a good media-blasting shop close by, I'd have it soda blasted, but make very sure they have experience with plastics. If you choose to sand it, do it by hand and be patient since using power sanders will quickly erase delicate body lines and since the parts are flexy, you can sand "dents" or lows in the part before you know it. So try hand sanding with a block or rubber backing pad, use 180-grit wet and get a comfy stool. Another question is, why strip it completely? If the paint is solid and not flaking off, and it's not too thick, I'd simply scuff it, fill any chips, then prime, scuff and paint.
Old 03-10-2010, 08:06 AM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Old 03-11-2010, 09:59 PM
e-tek's Avatar
e-tek e-tek is offline
e-tek has a good reputation on FTE.e-tek has a good reputation on FTE.
There's all sorts of bumper strippers. 3M also makes one. Ask at your local autobody supply store.
1955 Rear wall carpet ungerp 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 01-11-2015 05:19 PM
Chrome plastic 1984F2506.9 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 06-05-2013 08:12 PM
Black rubber strips down roof indents RadarRick 2004 - 2008 F150 1 08-04-2007 12:08 AM
Stripper daveengelson Paint & Bodywork 4 02-26-2004 12:51 AM
bondo for chrome strip holes? taberry Paint & Bodywork 7 10-09-2003 10:27 PM
Tags
abs, paint, plastic, stripping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
