03' F-250 won't start??? - Ford Truck Enthusiasts Forums
Old 03-09-2010, 03:07 PM
chiefn10's Avatar
chiefn10 chiefn10 is offline
chiefn10 is starting off with a positive reputation.
I turn the ignition switch to start--and nothing! all accessories and everything works fine. figured it may be the starter, so i replaced it, and same symptoms. Checked the fuses under the dash, and also checked the ignition relay, and everything looks good. any suggestions?
Old 03-09-2010, 03:11 PM
utjer utjer is offline
utjer is gaining momentum as a positive member of FTE.
How are your batteries?
Old 03-09-2010, 03:30 PM
chiefn10's Avatar
batteries seem to be fine. all accessories work fine, and the terminals are clear of any corrosion. i had the alternator replaced 2 months ago.
Old 03-09-2010, 03:34 PM
ljutic ss's Avatar
ljutic ss ljutic ss is offline
ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.ljutic ss has a great reputation on FTE.
Do you hear the fuel pump running when you cycle the key? After evaluating the batteries, you might want to check the secondary fuel filter to see if fuel is getting to it. I would then check FICM for the required voltage.
Old 03-09-2010, 03:40 PM
When my batteries went out I had power to all accesories. There just wasnt enough to turn the truck over.
Old 03-09-2010, 03:47 PM
chiefn10's Avatar
yes, i can hear the fuel pump running. the vehicle doesn't even turn-over, so it is not like it is starving for fuel. as i turn the key from accessory to start, nothing happens. it also seems that the key is not going all the way forward. i looked in the Haynes manual, but the electrical diagrams only cover up to 2002, even though it is for 99-06 models (stupid)!
Old 03-09-2010, 05:07 PM
ljutic ss's Avatar
Did you try starting with the shifter in neutral?
Old 03-09-2010, 05:19 PM
chiefn10's Avatar
yes, i was thinking the same thing as far as the transmission position sensor being bad, but that didn't work either. i am going to do a voltage check on the batteries again just to be sure they have enough voltage.
Old 03-09-2010, 05:43 PM
chiefn10's Avatar
well, the batteries are both reading 12.4 volts, so i know i have power.
Old 03-09-2010, 08:27 PM
teppler's Avatar
teppler teppler is offline
teppler is gaining momentum as a positive member of FTE.
Need to put a load on batteries to check them correctly just reading voltage doesn't tell you a lot. I take mine to Wal Mart where I buy them but most auto parts will check them for you.
Old 03-09-2010, 08:45 PM
chiefn10's Avatar
well, i called the stealership to get their opinion. they had me cycle the key from on to off 8-10 times to reset the computer, and i'll be damned if it didn't turn right over! never heard of this before.
Old 03-09-2010, 09:12 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Quote:
Why refer to them as a "stealership" when they helped out over the phone at no charge? I'd say they did you right.
Old 03-09-2010, 09:46 PM
ljutic ss's Avatar
If they helped me get my vehicle running free of charge, I would personally deliver a pizza and soda at lunch time to who ever I spoke to.
Old 03-09-2010, 09:53 PM
chiefn10's Avatar
ok, they helped me out, so they aren't that bad this time, but the did charge me $600 2 months ago to replace my alternator
Old 03-10-2010, 06:32 AM
bismic's Avatar
bismic bismic is online now
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
My experience is that a bad alternator is often followed quickly by a bad battery (or two). If that is your case, you can throw in an expensive FICM later unless you check it out thoroughly now. A voltage test is useless. Do the load test on each individual battery. I do it at least twice a year now as preventative maintenance - and I have new batteries. I also recommend considering the installation of a fuel pressure gauge - it is a great tool to use in troubleshooting, but more importantly - making sure you don't let the fuel pressure get below 45 psig will possibly save you a big injector bill.
Ignition Switch? '78F250351m 1973 - 1979 F-100 & Larger F-Series Trucks 6 03-04-2015 08:32 PM
ignition wiring? tronvader 1999 to 2016 Super Duty 0 02-13-2015 07:26 PM
1973 F-100 390 idles fine misses at rpm olddudeoldford 1973 - 1979 F-100 & Larger F-Series Trucks 9 01-11-2015 05:00 AM
Ignition coils Kennicol Modular V10 (6.8l) 12 02-23-2011 09:49 AM
81 electronic ignition no fire tandpr 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 02-13-2011 09:13 AM
Tags
03, 2003, 2005, 250, 60, diesel, f250, ford, powerstroke, start, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
