found new info on man trans oil types/specs - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-08-2010, 09:02 PM
6LPSD's Avatar
6LPSD 6LPSD is offline
6LPSD is starting off with a positive reputation.
Lightbulb found new info on man trans oil types/specs
hey guys found some info for you with the zf 6 speed, it seems ford is allowing you to use 2 options for the zf 6 speed a cheaper mercon v oil or what i would seem to be a more long term investment the syn man trans oil for long life and high heat protection. my early 2009 owner manual states to use the syn man trans fluid and then abruptly ford changed the specs later that year, i checked on the motorcraft website on any updated editions of my owners guide, they went to mercon v instead don't know why or for what advantage this may be other than a more cost effective solution for the consumer? below is a link you may want to check out to see what i am talking about. by the way does anyone know where i can purchase the 1 qt bottles cheaper than the dealers 19.00/qt. price?
http://fcsdchemicalsandlubricants.co...f/mantrans.pdf
Tags
08, 1999, f250, f450, man, oil, specs, trans, type, zf6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
