Inline 6 horrible gas mileage and low power? - Ford Truck Enthusiasts Forums
Old 03-08-2010, 07:12 PM
chevyassasin chevyassasin is offline
chevyassasin is starting off with a positive reputation.
I just bought a 87 f150 with the ole inline six and auto tranny. i knew it had this problem when i bought it (it was really cheap, that's why i bought it), but i don't know what all could be wrong. I figured maybe the cats were cloged but i can't work on it yet due to it bein at my aunts house which is very far away. But anyways it's gettin about 8 miles to the gallon and it don't have much power. What all could it be?
Old 03-08-2010, 08:16 PM
Argo's Avatar
Argo Argo is offline
Argo is gaining momentum as a positive member of FTE.
Just a stab in the dark...
Before jumping into the "replace a bunch of sensors" diagnostic approach that many are fond of, ensure that the basics are in order. Ensure that your plugs, wires, cap and rotor are ok on the ignition side of things, make sure the thermostat is ok and the proper temperature, make sure the air filter is clean, and the fuel filter is good (also be sure to check your fuel pressure).
Old 03-08-2010, 08:47 PM
SideWinder4.9l's Avatar
SideWinder4.9l SideWinder4.9l is offline
SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.SideWinder4.9l has a spectacular reputation.
Um, first off its a 300 I6, its not a fire breathing monster.....But seriously, My truck is a 94' w/ I6 & Auto and I get 13-15mpg around town.....Also its 2wd, but as soon as I got my truck I did the regular tune up; Plugs, Dizzy cap and rotory button, oil change and air filter, new HD Thermostat w/ upper and lower radiator hoses.....And VOILA! It clicks and clucks along like a charm....Also just got a new 2 1/4" exhaust from the rear catalytic convertor back.....It helps, trust me-
-Wes
Old 03-09-2010, 10:04 AM
Quote:
-Wes
I'm guessin that the fire breathing monster comment was saying i thought the 300 had tons of power. lol. I know they don't cause i've had 4 300s, but it's got nothin.How many mpgs were you getting b4 the tune up?
Old 03-09-2010, 10:11 AM
I think I'll start by looking at all the ignition, fuel, and air basics to make sure they're right, take the cats off (i'm puttin an exhaust on anyways), then start to replace sensors if none of that helps. I hope this don't cost me more than the trucks worth!!! lol
Old 03-09-2010, 10:36 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
I'm going to suggest you do some investigation before you spend a dime on parts. First thing to determine is if it has dual tanks and if they both work and if there is a fuel transfer problem between them.. which is real common. If it does have this problem then the active tank is overflowing the other and dumping fuel on the ground as you drive. Also check fuel pressure and for the presence of fuel in the vacuum lines attached to the fuel pressure regulator and throttlebody. If all this checks out then pull the codes to see if anything is flagged and fix those issues, and then do a tunup with new filters and fluids.
Old 03-09-2010, 08:02 PM
No ChevyAssassin....It was some of the off key humor I have....Any way...On the Pre-Tuneup MPG's, I couldnt honestly say, I only had the truck like 3 days to a week before the tune up....So I honestly dont know...Maybe some one can help me with this lil problem I seem to have accrued; I took my dash cluster out, swapped the clear lights for red ones, and took the gauge needles off and scraped the green film off so they show up bright, and now they seem to be off a bit...What would be the best way to reset them? I thought about letting the truck cool completely, and resetting the TEMP gauge to nothing, and the VOLT gauge allas ran about midways.......Any help will be greatly appreciated...Also, the speedo is still dead on...So IDK..
Thanks all-
-Wes
Old 03-09-2010, 10:57 PM
Brian Abington Brian Abington is offline
Brian Abington is starting off with a positive reputation.
its not too full of oil is it?
Old 03-09-2010, 11:07 PM
fordman1090 fordman1090 is offline
fordman1090 is starting off with a positive reputation.
Thanks all-
-Wes
Are you saying that the gauges are reading correctly? How far off are they? There isnt any way to reset the cluster that i know of. But i think you probably got a loose connection somewhere when plugging stuff in.
And also, when you put the cluster in did you make sure that non of the gauges where out of range? when i was messing with mine once, i didnt notice that one of them got pushed past where it could recenter it self and had to take it all apart again to fix it.
Old 03-10-2010, 01:26 AM
90GTDan 90GTDan is offline
90GTDan is starting off with a positive reputation.
Quote:
Originally Posted by Argo View Post
Before jumping into the "replace a bunch of sensors" diagnostic approach that many are fond of, ensure that the basics are in order....
Quote:
Originally Posted by Conanski View Post
I'm going to suggest you do some investigation before you spend a dime on parts. First thing to determine is if it has dual tanks and if they both work and if there is a fuel transfer problem between them.. which is real common. If it does have this problem then the active tank is overflowing the other and dumping fuel on the ground as you drive. Also check fuel pressure and for the presence of fuel in the vacuum lines attached to the fuel pressure regulator and throttle body. If all this checks out then pull the codes to see if anything is flagged and fix those issues, and then do a tuneup with new filters and fluids.
Bolding mine.
What these wise individuals said! ^^ Test don't guess! A quick check of the basics will save you a lot of trouble.
What you describe sounds like something I have encountered before on these trucks. I have replaced a number of fuel pressure regulators on the fuel injected sixes. Don't know what it is about this model. A check of the fuel pressure is definitely one of the first things to verify. With a bad regulator you can see well over 100 lbs of fuel pressure! They will run, but not well. It may also run for a couple of minutes before teh pressure goes batty on you. If that is the problem make sure you change your oil also because it will be full of fuel.
Recap: Check the basics and go from there!
Old 03-10-2010, 09:35 PM
Thanks guys. i'll start on it when i get the truck here
Old 03-11-2010, 12:47 AM
crestfallinman's Avatar
crestfallinman crestfallinman is offline
crestfallinman is gaining momentum as a positive member of FTE.
yeah i need to replace my plugs and wires, but definately change the exhaust, i would be careful touching the cats if you like your low end power, but a new muffler helps alot
i also have a k&n drop in filter, it seems to help but im not sure if the pain of cleaning it is worth the amount it helps quite yet haha
Old 03-11-2010, 04:20 PM
well i won't have to worry about this truck anymore, i just traded it for a newer (95) f150. Thanks so much though guys!
Old 03-11-2010, 06:52 PM
1996 Redneck F150's Avatar
1996 Redneck F150 1996 Redneck F150 is offline
1996 Redneck F150 is starting off with a positive reputation.
I get 9-10 mpg on a good day. I'm going to get high performance plugs, wires, dizzy cap, rotor, and a coil, then I'm going to do a timing bump! Before all of that, I'm going to Seafoam my truck. I'd be tickled pink if I got 13mpg after all that.
Old 03-11-2010, 11:49 PM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
i get 11.4 on a good day...mind you im turning 35s with 3.55s gears ...truck got roughly 15 before the lift/tires....not to mention the *******s that did the inspection on my truck topped up the rear diff with something like 130 weight oil? gotta change that back out for 80-90 then i might get some MPG back
1989 F150 302 FI--Power Drop jhutchison40 1987 - 1996 F150 & Larger F-Series Trucks 1 12-03-2016 07:11 PM
Swaping motor from a '86 F-150 to a '94 F150 Carl S. 1987 - 1996 F150 & Larger F-Series Trucks 4 12-02-2016 04:31 PM
Rebuild an inline-6 instead of a V8?! blueovalfan1 Ford Inline Six, 200, 250, 4.9L / 300 184 11-06-2014 01:51 AM
300 Inline Six Sound fordrules_2013 Ford Inline Six, 200, 250, 4.9L / 300 11 10-13-2013 07:33 PM
demo derby ? liquor crazy General Automotive Discussion 6 08-21-2013 06:08 AM
Tags
1996, 300, 95, 96, f150, ford, fuel, gas, increasing, inline, inline6, locations, mileage, mpg, thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
