300 c.i. I-6 identification - Ford Truck Enthusiasts Forums
Old 03-08-2010, 05:47 PM
vegas_kidd's Avatar
vegas_kidd vegas_kidd is offline
vegas_kidd is starting off with a positive reputation.
Just got a 79 fullsize bronco with a 300 in it yesterday and was wondering where I can find an identification stamping on the engine or anything else that might give me info on the year it was manufactured ect.. thanks
Old 03-09-2010, 09:19 AM
AbandonedBronco's Avatar
AbandonedBronco AbandonedBronco is offline
AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.AbandonedBronco has a great reputation on FTE.
If I remember right, there's a VIN number somewhere on the block, but I can't remember where. As a starter, you could find part numbers on main engine parts, such as the head, intake/exhaust manifolds. The first two numbers will be the year. D = 70s, E = 80s, F = 90s. Second number is the year. (ie. E1 = '81)
It won't be super accurate, because they can always put 79 parts on an 81 if they're on the shelf, but it'll get you into the ballpark of the engine's year, at least until you find the VIN.
Very cool on a 300 in a 79 Bronco. That's a fun custom job.
Old 03-09-2010, 09:29 AM
chrlsful's Avatar
chrlsful chrlsful is offline
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
nice year! Welcome to the FTE!
There's some helpful folks on here, & much more knowledgable than me. I got alot of pointers and saved work and money here. Hope you enjoy.
I would say look beside the down draft tube on your exhaust. That's cuz mine is there. On the passenger's side, middle of the block top to bottom/left to right. Should B letter, number, letter, letter. Mine is C 8 D E. The first signifies decade - yours should B "D" for seventies. Next is yr of that decade "8", so we have a 1968 in my case (yours D8 I'd guess).
I had to scrape away grease n oil/dirt to find mine. Found that some 1 put the right displacement motor, but from a 2 yr older car. Answers alot of other Qs in my case.
Stick around some 1 more knowledgable will ck in shortly...
Old 03-09-2010, 11:04 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
The block/head casting numbers do not mean the year of the engine, per se. The casting numbers didn't change every year, just when the molds were updated. This was typically only done when there was a revision in the design, or the molds wore out from use.
It's totally possible to find casting numbers on a block that are 8-10 years older than the chassis, even though the engine is original. If the engine didn't go thru a major revision, and the mold was still in good shape, why toss it out?
Old 03-09-2010, 01:17 PM
Col Flashman's Avatar
Col Flashman Col Flashman is offline
Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.Col Flashman has a very good reputation on FTE.
Thank'ee, mate.
Nice to see that someone else knows that FoMoCo didn't follow GM's lead w/ Matching serial numbers on every bleedin part on every single individual vehicle. c];-)
Old 03-09-2010, 01:23 PM
Quote:
Originally Posted by Col Flashman View Post
Thank'ee, mate.
Yeah, FoMoCo did things their way, which was pretty much "If it ain't broke, don't fix it"........
Old 03-09-2010, 09:02 PM
vegas_kidd's Avatar
thanks for the info - i guess basically i need to know so I can get parts for it and since it isnt the original motor it could get complicated at the parts store. lol. first thing I need to get is an oil filler cap, the shop rag thats plugging it just doesnt do it for me!!
Old 06-05-2012, 04:27 PM
Don Oat Jr Don Oat Jr is offline
Don Oat Jr is starting off with a positive reputation.
I have a 1964 Mobile Canteen from a New Jersey Fire Department that has all of it's original body paint , some of the lettering and a brand new kitchen inside. Really well maintained. The chassis came from Ford and the body came from Boyertown Body.
The problem is I can only find 1 vin on the top of the right front rail, behind the axle. People at Ford can't figure this one out and I thought you might have some idea of what I have here or even an idea of where another vin would be. The vin is p40JL540209. It looks as though most of the engine is original equipment (7,000 miles) I have new exhaust and now a new water pump in the year that I have owned it.
Thanks in advance for any assistance you can provide.
Don Oat
fbbakery@yahoo.com
Old 06-05-2012, 11:45 PM
jem44357's Avatar
jem44357 jem44357 is offline
jem44357 is starting off with a positive reputation.
This may shed some light on the subject...
http://www.ford-trucks.com/forums/11...date-code.html
HTH
Jim
Old 06-06-2012, 12:06 AM
jem44357's Avatar
Don Oat
fbbakery@yahoo.com
Do you have any pics?
Incase you have not looked here they may know...
Boyertown Museum
I found this interesting, it gets pretty deep if you start clicking around ...
Boyertown Body Works, Boyertown Auto Body Works, Boyertown Carriage Works, Ltd., Paul R. Hafer, Boyertown Body and Equipment Co., Battronic - Coachbult.com
Sorry if it is info you have already researched.
Jim
'04 screw front seat removal vegas_kidd 2004 - 2008 F150 16 04-18-2010 11:16 PM
Arizona beige vegas_kidd 2004 - 2008 F150 2 01-31-2010 09:01 AM
turn signal 62kidd 1961 - 1966 F-100 & Larger F-Series Trucks 0 11-12-2009 08:12 AM
How do i tell if my truck is an idi? The Kidd 250 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 02-29-2004 07:04 PM
Exhaust Kidd Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 4 04-03-2002 10:03 AM
Tags
1981, 300, 49, 49l, casting, ci, cid, engine, ford, identifacation, identification, inline, location, numbers, stamp
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
