Sign in using an external account
Welcome to Ford Truck Enthusiasts Forums
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community,
at no cost , you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please
join our community today !
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
SPONSORED BY:
03-08-2010, 05:18 PM
Exclusive photos of 2011 Super Duty launch event
Hi guys,
Recently, we were fortunate enough to get an in-depth look and ride of the new 2011 Super Duty. Here are all the pictures below, which you can view as slideshows on our homepage. We also have a great article detailing the experience.
Check it out and give us your thoughts as well. Thanks!
Slideshow 1
Slideshow 2
Launch Event Part 1
Launch Event Part 2
view of Prescott Valley from first night's hotel room
F450 King Ranch
6.7 diesel & 6R140 trans
diesel oxidation catalyst , DEF dosing module & DPF
6R140 trans
6.2 gas engine
6.2 in F250
Super Duty's in Hotel parking lot - Prescott
First stop in Kirkland Az
head unit&climate control
chassis/w 6.7 diesel
6r140 trans
6.2 gas engine
pass side 6.7 diesel
rear of 6.7 showing CCV system
view if 6.7 turbo
driver's side 6.7 showing ccv system
ccv system
rear of 6.7 showing turbo waste gate
view of grade where towing demonstration took place
parked near congress, az
exhaust emissions system as installed
front view chassis
F550 demonstration vehicles at the quarry
trucks at quarry after drive from Congress
part of quarry
various axles identified
"tool link" screen - part of "ford Works Solutions"
optional HP printer
power points
locking storage beneath rear seat
F550 at work pulling 33k lbs
F450's pulling 85k lb Caterpillar D988's
F550 dump bed during "live drive PTO" session
F250 in quarry
F550 dump bed
F250 on off road course
F250 at Renaissance Hotel in Glendale, AZ where we stayed the second night
33k lb load behind F550 in quarry
dump bed F550
Room (obviously ) and view of Prescott Valley from balcony thereof
6.2 liter gas motor. 2 spark plugs per cylinder, 2 valves per cylinder
6.7 diesel
6R140 trans
with DEF dosing module, DPF, exhaust sensors, and oxidation catalyst
6R140 trans
Spin-on oil filter - 6.7 diesel 10w/30 oil recommended.Change interval is determined by computer based on riving style...can go up to 10k miles
GCI engine block
Passenger side of 6.7 showing twin egr coolers. In some running strategies the engine will use up to 60% EGR
Variable Geometry Turbo
Composite intake manifold
Front view 6.7
composite oil pan - 6.7
aluminum heads
internal vibration damper from torque converter used/w 6.7 diesel engine
self explanatory
6.7 cylinder/head cutaway
turbine wheels - 6.7
6.7 diesel
F450 King Ranch
F250 XLT
F450 King Ranch
Bed of F450 King Ranch showing Ford's integral 5th wheel/gooseneck system
cable lock and inside the bed mounted trailer plug
6.7 diesel twin compressor wheels
6.7 externally mounted oil cooler
6R140 trans
Waste gate for 6.7 diesel's Variable Geometry Turbo
6.7 pass side cutaway
internally mounted vacuum pump - 6.7 diesel
6.7 diesel piston - new bowl design
6.7 diesel - valves, rocker arms
CCV system -6.7 diesel. Internal baffles to coalesce oil mist.
6.7 composite intake
self explanatory
rocker arms - 6.7
6.7 roller lifter - 2 pushrods each
oil drain plug in composite oil pan -6.7. 3/8" drive - removes with 1/4 turn
Trucks parked outside hotel - Prescott
Motel/restaurant/bar/roadhouse in Kirkland, Az
6.7 turbo
top cutaway view 6.7 twin compressor wheels
integrated 5th wheel/gooseneck installation
front end of cassis/cab configuration
23k lb trailer behind F450
5th wheel behind F450
F450/w 23k lb trailer
gooseneck ball
new asymmetric cooling fan design
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
03-08-2010, 07:13 PM
At least they're better looking than the 08-10, the grill being shaped more like the 05-07 is much better
__________________
Bryan -
2007 F-250 6.0L PSD FX4
295-70R18 Nitto Trail Grapplers, Ranch Hand Legend, Edge Insight CTS
B&W Gooseneck, PHP Atlas 40 FICM Tuning , Dfuser Coolant Filter
03-08-2010, 07:23 PM
hmmm anyone else notice the F250 and F350 axles appear different now ?
did the F350 move up to the Dana 70 by chance ??
p.s. it also appears someone stole the piston display for the new 6.2... haahahh
__________________
2003 F250 4x4 CC V10 4" Procomp, all white beauty
"list of previous owned Fords much to long to list here.."
03-08-2010, 07:29 PM
Holy cow! Awesome pictures, thanks a bunch for posting up all of those.
What's up with the 411HP for the 6.2L on that one sign? Is that only for the Raptor?
03-08-2010, 07:33 PM
Yep...the standard 6.2 is rated 385.
03-08-2010, 08:56 PM
looks good.....most pics I have seen. Being from AZ, I know the area that the tests took place....looks like a good time! Can't wait to try them out in person.
__________________
~Justin~ 2005 F150 XL 4.2L V6 -2.5" Autospring Leveling Kit, Flowmaster 40 SIDO Exhaust Before Rear Tire, Airaid Filter and Shield, SCT X3 W/ Custom Tunes, Scangauge II W/ X-Gauge,
2012 Ford F250 XLT FX4 - Dream Truck/Work Truck
03-08-2010, 09:29 PM
Does anyone know of a easy bank to rob?
__________________
03-08-2010, 10:16 PM
Super Jealous right now . I would still be drolling after that awesome trip. Thanks for all the pics.
03-09-2010, 05:35 AM
The oil drain plug is interesting.I like the factory mounted 5th wheel,gooseneck set-up,very clean.Nice looking trucks.
__________________
Steve
2000 F-250 XLT 7.3L 4x4 LB
03-09-2010, 06:07 AM
2005 Ford F-350
Great pictures Thank you. Holy crap I cant wait.
03-09-2010, 10:21 AM
Well, I guess I laughed at the fenders on my buddy's dodge to hard. Now Ford comes out with the same UGLY fender on the dually.
__________________
RICK, PAA MEMBER #4
2001, F-350, DRW. CC. LWB, 4X4, LARIA T,
MODS: 6637 W/Pete's cover, BTS-TRANS, DP-TUNER LIVE , MBRP 4" SS, Isspro 3 gauge kit, TN-BB turbo, Bellowed up pipes, HPX, TRU-COOL cooler, SS Stage II injectors, and the Chris-fifty.
03-14-2010, 11:06 AM
I actually saw one of these driving near Speedworld in Wittmann during the Desert Diesel Nationals. They look much better in person.
__________________
Peter - NHRDA# 5078 - Member of the 200K+ club
2000 Excursion 7.3 -
Casserly Stage 1 SS ,
6637 w/ Pete's cover , van turbo, ceramic coated exhaust manifolds,
IH up-pipes , and exhaust housing,
RDP Billet Compressor Wheel , Live Tuned by
DP tuner ,
Warn hubs , gauges, 6.0 IC,
MBRP 4" turbo back ,
Frx ,
RDP AIH delete ,
RDP OCR ,
RDP IC boots ,
RDP CCV kit ,
John Wood Trans ,
Melling LPOP ,
T500 ,
Red Head Steering Box ,
RDP Billet Plenums, 5" lift, B-code springs. and
RAS .
03-14-2010, 01:58 PM
2011 Ford F-150
Thanks for sharing Adrian! I love the new fender flares on the dually,it gives the truck a whole new look aft of the cab.
I'm really excited for Ford right now. I know the 6.2L is going to be a great engine and I feel that they have done all the right things right on the 6.7L.
__________________
Tim
SCPO United States Coast Guard Retired
2011 F-150 XLT 4x4 Ecoboost
2010 Ford Focus
2004 Expedition XLT 4x2
FTE Guidelines
03-14-2010, 02:06 PM
I like the dually fenders also Tim, but from what I've heard from others we are definitely in the minority with our opinion.
03-14-2010, 02:15 PM
2011 Ford F-150
Quote:
Originally Posted by
SteveBricks
Oh well, I've stood alone and with minimal friends before!
I always liked th at style fender when Dodge was using them.
__________________
Tim
2010 Ford Focus
FTE Guidelines
Tags
2011 , 67 , colors , cutaway , date , duty , engine , ford , interior , king , launch , pictures , ranch , release , super
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
