89 ford ranger wont start - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-08-2010, 05:17 PM
cdnmshoem2002 cdnmshoem2002 is offline
cdnmshoem2002 is starting off with a positive reputation.
i have a 89 ford ranger 5 speed that when ever i go to start it i press the cluch in and turn the key and all it does is CLICK CLICK i have replased the battery and the starter solenoid and had the starter checked at 2 diffrant places and it still just CLICKS i need help please or just send me c4 so i can get rid of the dam truck
Old 03-08-2010, 06:25 PM
Torgmada Torgmada is offline
Torgmada is starting off with a positive reputation.
The battery and the alternator tend to go together- I've had to replace both in my 89 crown vic and my 2002 Ford ranger.
You might have replaced the battery just to have it killed by a bad alternator. And if you did kill that battery, it could easily take out the next alternator.
Click click click.... sounds like the classic low power problem.
Also, I'm fresh out of C4.
Old 03-08-2010, 08:44 PM
87 XLT 87 XLT is offline
87 XLT is gaining momentum as a positive member of FTE.
I'm also fresh out of C4.
Like Torqmada sez it looks like you're not getting enough juice to the starter.
When I had the same problem on my 87 2.9 I found a bad battery cable with this VERY simple little test.
I used one side of a set of jumper cbles & jumped from the positve battery post to the starter relay. No joy, it still would'nt crank.
Jumped from the negative battery post to the engine block & when it fired right up I knew the negatve battery cable was shot.
8 bucks for a 6 inch battery pig tail at Kragen & problem solved
Old 03-09-2010, 01:15 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
I am going to assume that you know when you have a fully charged battery. What solenoid did you replace the fender one or the one on the starter. if it was the fender one then when they tested the starter did they also test the solenoid on the starter. if those all work out fine you might consider the clutch positioning switch.
* also i agree with 87xlt to check your cables they can disintegrate under the plastic.
Old 03-09-2010, 05:13 PM
Yep, the negative cable was eaten away under the insulation near the battery post.
Did'nt want to bother replacing the entire cable so I just replaced the last 6 inches of it with the pigtail.
I had to get a pigtail that included the smaller ground wire for the ECM ground & I made my own short chasis ground wire out of some old wire I had laying around.
Been working fine for about 4 years now.
Old 03-09-2010, 06:48 PM
97ranger xlt's Avatar
97ranger xlt 97ranger xlt is offline
97ranger xlt is starting off with a positive reputation.
make sure the small wire that attaches to the solenoid on the starter is on good and tight.
i had an issue recently of just getting the click and found the small wire loose.
Can my starter freeze? Help! mark227 1999 to 2016 Super Duty 10 12-17-2016 03:54 PM
1999 ford ranger 3.0 lt 4wd manual Kylez General Automotive Discussion 0 07-22-2015 05:32 PM
87 ranger no power effenzee Ranger & B-Series 9 07-10-2012 06:54 AM
Please Help Me Troubleshoot My Starting Problem... rutang Ranger & B-Series 2 01-07-2010 11:35 AM
Truck will not start - "Click" when turning key? aguylookingforadvice 1987 - 1996 F150 & Larger F-Series Trucks 23 04-19-2006 07:27 AM
Tags
23, 87, 89, alternator, click, clicks, ford, juice, pigtail, ranger, solenoid, start, starter, truck, wire, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
