Rear end movement - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Rear end movement
Old 03-08-2010, 05:12 PM
Mud-and-Guts's Avatar
Mud-and-Guts Mud-and-Guts is offline
Mud-and-Guts is starting off with a positive reputation.
Rear end movement
1999 f250 super duty supercab..... f350 4 inch rear blocks
I bought this truck a month ago and ever since I bought it I have noticest when I come to a stop and take off I have what feels like movement in the rearend. I do not notice it unless I come to a complete stop. I have checked and found nothing loose in the rearend and was wondering if this could be normal in the springs and bushings???
Old 03-08-2010, 06:14 PM
drperformance drperformance is offline
drperformance is starting off with a positive reputation.
Its normal axle wrap created by the shackles connecting the leaf springs. My 2009 does the same thing forget about it or buy a truck with coil springs in the rear.
Old 03-08-2010, 07:07 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
My rear end gets lots of movement when I eat Mexican...Sorry I couldn't resist.
Axle wrap is one thing it could be. It can be combated in several ways. Some of them fairly cheap and some of them not so much.
Do you only get this when pulling a tralier? If so then it sounds like axle wrap. Taking off rather gently from a stop while unloaded shouldn't produce axle wrap.
Old 03-08-2010, 07:11 PM
Fordfanatic4life Fordfanatic4life is offline
Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.Fordfanatic4life has a very good reputation on FTE.
my guess is your feeling the drive shaft slip joint "clunk" which occurs just as teh vehicle comes to a complete stop.
its simple to regrease the splines...
texastech_diesel's Avatar
texastech_diesel texastech_diesel is offline
Disgruntled Texan
texastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputationtexastech_diesel has a superb reputation
Could be a few things, like sagging springs, shot spring bushings, slop in the ring and pinion, worn u-joints, worn out shocks, a touch of axle wrap, or more likely a combo of all of the above. It's a 10 year old truck, things start to get loose after awhile.
Old 03-08-2010, 07:37 PM
Quote:
That's what I was hoping to here..... This is the first truck I have had to do it is the reason I was asking, but with the 4 inch blocks I was assuming that it was normal.... This is my first Super Duty....
Much thanks bro,
Old 03-08-2010, 07:41 PM
Quote:
I May try changing the bushing later on to see if it helps.... U-joints, ring and pinion check out fine.... It seems this truck was used to pull a heavy load so I was assuming it may be the bushing... everything seems tight when I check it out so I was hoping it was just normal movement.... I was also assuming the 4 inch blocks may play a part causing more axle wrap....
This is my first super Duty..... First with 4 inch blocks....
Thanks for the info,
Old 03-08-2010, 07:45 PM
I do need to regrease the splines they have a little play...... I may regrease them tomorrow to see if helps any...
But it don't feel like that it feels like the springs are twisting....
Old 03-08-2010, 11:52 PM
redford's Avatar
redford redford is offline
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I had a truck with one bad shock out back that would do strange things like that. One side would compress and one side wouldn't. It was very noticeable when stopping or going over speed bumps, felt like the rear axle was pivoting under the frame.
Old 03-09-2010, 10:25 AM
Quote:
Interesting......
I was planning on changing the shocks at a later date but it may come sooner than later....
I have no problem at speed bumps it just feels like the rearend twists in one direction when I come to a complete stop and twists in the other direction when I take back off.....
It does not do it at a rolling stop I only notice it at a complete stop...
Actually feels like a wheel is loose and moving at stop and go.
Old 03-09-2010, 01:26 PM
SteveH-CO SteveH-CO is offline
SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.SteveH-CO has a good reputation on FTE.
You could have a wife/friend put it in and out of gear (fwd and reverse) and watch the rear axle mounting points, or relation of the wheels to wheelwells. Light power braking might induce some movement, too.
Use great care doing this - don't get run over.
Old 03-09-2010, 03:42 PM
I have come to the conclusion it is axle wrap that I am feeling.....
I got out today and had my wife pull the truck back and forth as I watched the rear dif, springs, and bushing to find the bushing are tight but the springs (I believe) are the movement I am feeling....
I also used a grease needle and greased the drive shaft by sliding the needle under the boot and squirting grease.....
Much thanks to all,
Old 03-16-2010, 11:27 PM
I may have been wrong as to where the wrap was coming from. I was thinking it felt like it was coming from the rear but This afternoon I installed the front leveling leafs from Rough Country and it seems to have fixed the problem. When stopping it does not shift as it did before.
Bad vibration/grinding in driveline Fordboy2011 2009 - 2014 F150 2 11-25-2016 09:08 PM
rearend swap dumptruck denny Clutch, Transmission, Differential, Axle & Transfer Case 1 02-20-2016 07:48 PM
65 ford f100 rearend ? diesel jim 1961 - 1966 F-100 & Larger F-Series Trucks 1 09-17-2013 08:40 AM
Lightning Rearend 9.75 HELP!!! tOSU Lightning Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 3 12-02-2012 03:15 AM
volt gauge movement tom237 Electrical Systems/Wiring 7 02-28-2004 01:39 PM
Tags
00, 2000, duty, end, f250, f350, feel, ford, loose, lose, lots, movement, rear, rearend, slop, super, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
