Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-08-2010, 02:44 PM
daddyjustang daddyjustang is offline
1995 Ford F-150
My Garage
daddyjustang is starting off with a positive reputation.
where to find polyurethane motor mounts?
I can't find them or even solid ones.
  #2 (permalink)
Old 03-08-2010, 02:51 PM
zxwut?'s Avatar
zxwut? zxwut? is offline
Garage is empty, add now
zxwut? is gaining momentum as a positive member of FTE.zxwut? is gaining momentum as a positive member of FTE.
What are your plans? Rubber feels much nicer.
__________________
2009 Focus
2008 Hayabusa with lots o' engine/suspension/brake stuff done, 190hp, 113ft lbs torque......without the nitrous
2006 Husqvarna SM510R uncorked and unrestricted
2003 Honda 954RR all stock
  #3 (permalink)
Old 03-08-2010, 03:00 PM
1995 Ford F-150
My Garage
I want something stronger than stock rubber. Preferably for the transmission also.
  #4 (permalink)
Old 03-08-2010, 03:44 PM
skyfox10's Avatar
skyfox10 skyfox10 is offline
1996 Ford F-150
My Garage
skyfox10 is gaining momentum as a positive member of FTE.skyfox10 is gaining momentum as a positive member of FTE.
Well, If someone is capable of taking the old mount hardware and replacing the rubber. I could send a solid piece of bedliner.
50% polyurethane
50% polyurea
Click the image to open in full size.
__________________
A modern classic 4x4 with 351 cubic inches of get you there in time.
  #5 (permalink)
Old 03-08-2010, 04:02 PM
1995 Ford F-150
My Garage
If I can't find some already made , I do plan on making my own. Probably fill with 3M window weld.
  #6 (permalink)
Old 03-08-2010, 08:13 PM
mikehawk's Avatar
mikehawk mikehawk is offline
mikehawk is starting off with a positive reputation.
Let me know how that works out. I just replaced my motor and trans mounts not too long ago, and even with brand new rubber it still feels sloppy. I'd be interested in solid mounts if you can find/make them.
__________________
88' F-150 XLT Lariat 5.0, M5OD
Andrew
  #7 (permalink)
Old 03-08-2010, 08:37 PM
skyfox10's Avatar
1996 Ford F-150
My Garage
Yeah, I would be interested to know how that works. I one bad mount now and may be doing a swap this week... But I also may not. Just depends on how lazy I am.
__________________
  #8 (permalink)
Old 03-11-2010, 09:40 PM
1995 Ford F-150
My Garage
I now have all new mounts and the window weld. Now to find the time to do it.
  #9 (permalink)
Old 08-02-2010, 10:30 PM
BigBlueOx's Avatar
BigBlueOx BigBlueOx is offline
1996 Ford F-150
BigBlueOx is starting off with a positive reputation.
I know it's a little late but I thought you might like these. Also for future reference to someone else that might be looking for poly engine mounts.
FT302N 80-96
__________________
Steve
'96 F-150XL Reg Cab Long Box 5.8 M50D 4X4 6" Skyjacker lift with extended radius arms. 33" tires. 3.55's with front and rear auto lockers. Swaped in Quad shocks, V8, BW 44-07 transfer, power windows, locks, mirrors, tilt wheel, speed control, and tach.
'97 F-350XL 5.8 E4OD Chassis Cab
  #10 (permalink)
Old 08-02-2010, 10:54 PM
nighthawk285's Avatar
nighthawk285 nighthawk285 is offline
nighthawk285 has a good reputation on FTE.nighthawk285 has a good reputation on FTE.nighthawk285 has a good reputation on FTE.
Also, there's these....sorry I didn't see this way back when you were asking about 'em
Super Duty Poly Motor Mounts,302,351W
__________________
2005 F350 4X4 King Ranch CC, LB, Leveling kit, 35" Toyo M/Ts, 4" turbo back, AFE intake, Blue Spring......so far
1987 F150 4X4 Reg Cab LB, 351W EFI, ZF-5, 4.10s, 5.5" Lift with Deaver Prerunner Springs, 35" Firestone Destination M/Ts, Ford 9" Rear, Dana 44 SAS in progress
  #11 (permalink)
Old 08-02-2010, 11:11 PM
BigBlueOx's Avatar
1996 Ford F-150
Props to you bud......those are a lot more affordable.
__________________
Steve
Tags
1987, 88, 95, f150, ford, lariat, lightning, motor, mount, mounts, poly, polyurethane, solid, transmission, urethane, xlt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
