how to raise a rev limiter?
it cuts out at only 4500. I don't think a aftermarket rev limiter will do any thing. I could be wrong but i believe it is a fuel shut off in the ECU. I dont know where i can get a custom tune for it. The few places in my area don't want to or know how to do anything other than mass air mustangs.
on
There is no rev limiter at 4500rpm so if your motor is dying it's because of loss of fuel pressure or a weak ignition system. The usable rpm range on an all stock motor is about 5500rpm.. above that the valve springs will allow valve float. FWIW I believe the stock ignition rev limit is around 6000rpm.
Do you know what the catch code of your ECU is? That's the 3 letters and one digit code on the ECU in a font 3 times larger than the rest of the numbers. It may also be on the door jamb. That's the code that you need to find out if there is a def file for your ECU. Less important is whether it's an EEC-IV or EEC-V.
what if I direct wired the fuel pump? maybe put a switch in the cab that i can turn on just when i'm pulling. would the engine run safely to about 5000 rpm?
or is does it just shut the injectors off?
hitting that limiter is hard on stuff when i'm pulling. that big RPM drop then back to full power makes quite a jerk, and the loss of momentum really hurts how far I make it down the track.
I really couldn't say how safe it is to run to 5000. Most of the fuel and spark calibration is set up for a range up to 4400, so if the engine suddenly needs more fuel or less spark after 4400, it isn't going to get it.
Ford intended as a complete shut off. Some cars have softer "half fuel" cutoffs before the hard one, but not the 460s.
7622RM
1983 - 2012 Ranger & B-Series
12-11-2018 05:34 PM
95BroncHO
1978 - 1996 Big Bronco
06-24-2014 02:10 PM
zmock8
04-13-2009 02:50 PM
