How many RPM's at 75mph? - Ford Truck Enthusiasts Forums
Old 03-08-2010, 12:02 PM
offrdmania's Avatar
offrdmania offrdmania is offline
offrdmania is starting off with a positive reputation.
My truck runs at 2300rpm at freeway speeds. Is this right?
Old 03-08-2010, 12:39 PM
donbrown donbrown is offline
donbrown is starting off with a positive reputation.
Better than mine . Do you have 4.10 gear ratios? I think you might have 3.73 cause mine is over 2600 RPM at 75MPH 60MPH is around 2000 RPM
Old 03-08-2010, 12:48 PM
JamesHajek's Avatar
JamesHajek JamesHajek is offline
JamesHajek is gaining momentum as a positive member of FTE.JamesHajek is gaining momentum as a positive member of FTE.
Ya i got 4.10 as well and i turn around 2500 at about 75 so you must be turning 3.73 gears.
Old 03-08-2010, 12:51 PM
offrdmania's Avatar
Yes, mine has 4.10's. Im wondering if yours isnt shifting into OD?
Old 03-08-2010, 12:58 PM
Quote:
Mine is an 5 speed manual.
Old 03-08-2010, 01:05 PM
Duradan's Avatar
Duradan Duradan is offline
Duradan is starting off with a positive reputation.
At 85 on the way back from phoenix I was doin 2500 rpm roughly at 85mpg...
3.73's
Old 03-08-2010, 01:55 PM
JamesHajek's Avatar
mine definitely shifts into OD.
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 03-08-2010, 02:58 PM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
2250 RPM @ 70MPH is about normal with 4:10's and OEM size tires.
The speed-o is programmable for different size tires.
http://www.ford-trucks.com/forums/82...orrection.html
Old 03-08-2010, 03:46 PM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
'95 4x4 5-speeds (one ECLB one RCLB), stock 235/85R16s, 3.55s, both do exactly 2000 RPM at 70 MPH. Equates to aprx. 2140 RPM at 75 MPH.
Same tires, same tranny should do aprx. 2250 with 3.73, and 2475 with 4.10.
Old 03-08-2010, 10:48 PM
mountaineer27's Avatar
mountaineer27 mountaineer27 is offline
mountaineer27 is gaining momentum as a positive member of FTE.mountaineer27 is gaining momentum as a positive member of FTE.
can you hit 75 mph without od? mine sure wont. 55 and shes redlined
Old 03-09-2010, 12:28 AM
What kind of fuel mileage do you get with 3.55's?
Old 03-09-2010, 12:59 AM
Quote:
17-18 in town, aprx. 20-22 on the highway. Best we ever got was 24. All stock; haven't even done the 6637 mod.
Old 03-09-2010, 10:32 AM
nateairman's Avatar
nateairman nateairman is offline
nateairman is gaining momentum as a positive member of FTE.
I have done some calculations on my mileage and the results are not so great! looks like I am getting just over 7mpg!!! What the heck. Dualls 4x4 make a huge differance or what? not sure on my rpms at 75mph cause we don't have a very straight rode around here. Lots of steep hills though.
Old 03-09-2010, 12:14 PM
I have a 97 crew 4x4 F250 and get 14 MPG in the city (35MPH) and 18 MPG on the HWY(70MPH) . That is at sea level with a pint of 2 cycle in the tank and a little DieselKleen.
Up in the mountains 3000-8000 feet on hilly roads going 40 MPH consumption goes to 10-12 MPG.
Old 03-09-2010, 12:18 PM
rideracelivemx7's Avatar
rideracelivemx7 rideracelivemx7 is offline
rideracelivemx7 is starting off with a positive reputation.
these trucks didnt come with 3:73s? only the superdutys, we have 4:10s or 3:55. and im screamin at 75 wiht 4:10s but my last truck has 3:55s and loved it on the highway. ***70mph***edit** was like 2100 i think.
Spark & rpm skidmarks82 1997 - 2003 F150 2 10-05-2015 08:45 AM
Rpm range JoeDaf Ford Inline Six, 200, 250, 4.9L / 300 21 08-19-2015 11:33 AM
C6 Shifting at 4000 RPM. danlee Clutch, Transmission, Differential, Axle & Transfer Case 11 02-02-2013 06:40 PM
302 RPM redline eco Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 01-28-2006 10:03 AM
Rpm's too high? oldblue18 1978 - 1996 Big Bronco 7 09-04-2002 10:48 AM
Tags
150, 2010, 2600, 75, 75mph, 95, 97, diesel, f150, f250, high, mph, overdrive, rmps, rpm, rpms, run
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
