what is the biggest tyre size you can fit on a ford f250 7,3l idi diesel 1991
Old 03-08-2010, 09:37 AM
dark_flame221's Avatar
dark_flame221
dark_flame221 is offline
THe title said it what is the biggest tyre size you can fit on a ford f250 7,3l idi diesel 1991 ?!?!? thx... !
Old 03-08-2010, 09:41 AM
LCAM-01XA's Avatar
LCAM-01XA
LCAM-01XA is offline
4x4 truck, all factory suspension? Your stock tires are 32" in diameter so 33s will fit in just fine unless they're stupid-wide. 35s may fit too, but you'll probably have some rubbing when you turn the steering wheel all the way to left or right.
Old 03-08-2010, 11:56 AM
Sycostang67's Avatar
Sycostang67
Sycostang67 is offline
Wheels will make a difference too. You can put taller tires on factory wheels. Most aftermarket wheels are wider with more offset and will cause rubbing with smaller tires. I'm running 285/75R16's(32.84") with no issues.
Old 03-08-2010, 09:44 PM
dark_flame221
thx a lot guy's for the quick reply it will help me a lot to know where to start searching ... ! and... wow didnt knew there were that much poeple here! i had to look in 3 page of new thread to find mine.. lol big community here nice !!!
Old 03-09-2010, 01:54 AM
ichabod40's Avatar
ichabod40
ichabod40 is offline
I'm running 315/75R16 on my truck, '93 F-250 no lift. The bumper needs to be trimmed about an inch or two, though. Alternatively, could just put some spacers in between the bumper and the frame.
Old 03-09-2010, 11:07 AM
LCAM-01XA's Avatar
LCAM-01XA
That's cause you got the aero front clip tho - the '87 to '91 bricknose style like Dark Flame's have more spacer around the wheels, so trimming the bumper may not be necessary for him.
Old 03-09-2010, 11:56 AM
dark_flame221
So 315/75/16 will still fit ? its 34,6 inch in diamater its like 2 inch more than the 285.. would the tire be rubbing too when steering at max ?
anyway 33s still gonna be big 6 inch biger than the stock one, equivalent too a 3 inch lift...
Old 03-09-2010, 12:36 PM
Blue Rebel's Avatar
Blue Rebel
Blue Rebel is offline
yes, on a 91 f250 35s will fit
Old 03-09-2010, 07:46 PM
dark_flame221
Without rubbing at all ? when steering at maximum ? thx
Old 03-09-2010, 07:52 PM
LCAM-01XA's Avatar
LCAM-01XA
How you figured that out? Factory size tires for you is 235/85-16 (unless you have a 2wd dually) which is a 32" tire. And 35s ain't usually really 35" in diameter, but slightly smaller... And if they happen to run at full turn, well then just don't turn the wheel as much - I have that going on with my truck, I misjudged the bumper end supports and now my tires hit them at full lock, so I just make wider turns - no big deal once you get used to it.
Old 03-10-2010, 10:25 AM
dark_flame221
k i tough i read somewhere that the stock tire where 185/75/16 for my truck so 27 inch in diameter than fitting some 33s would add give me 3 inch of lift
Old 03-10-2010, 12:17 PM
Blue Rebel's Avatar
Blue Rebel
stock tire size on these trucks was 235/85r16. equals out to about 31" tall.
And no, they will fit tall ways, but will rub side to side on the leaf springs at full turn. Does no damage, just cant turn as sharp
Old 03-10-2010, 08:36 PM
dark_flame221
sorry for quoting you again, but i see that have have lifted a 89 (same as an 91), would like too to lift mine, add did you lift it ? with a kit, did you did it yourself, how much did cost ? thx a lot whats your name ?
Guillaume Dubois...
Old 03-11-2010, 08:06 PM
Blue Rebel's Avatar
Blue Rebel
My 89 currently has a 4" suspension lift on it, made by rough country. bought it for about 600 bucks new from national tire & wheel. I put it on in my driveway in a weekend.
And the names Josh
Old 04-21-2010, 09:45 AM
dark_flame221
ok, now what my wheel bolt pattern ?! thx
Quick Reply: what is the biggest tyre size you can fit on a ford f250 7,3l idi diesel 1991
