Need Tire/Lift help please....
Alright so i know i have been posting a lot of these threads lately, but i need help deciding what to do. The situation is that i really want to do the 6inch in the front and 3 inch in the rear Pro Comp lift since it is 2wd. There is a thread on here of a guy running that same set up on a 2wd with 35x12.5/16's and it looks awesome. That kit recommends to run 35 inch tires which would be perfectally fine however, but the rims i am buying are only 6 inches wide and i take it you cant run a 12.5 inch wide tire on a 6 inch rim and nobody seems to make a 35 inch tire that is any narrower. So i just got off the phone with the guy and he recommended using a 285/75/17 which is a 34 inch tall tire by 11 inches wide.
My question is, will a 34 inch tire look to small for that lift??? I dont want to get that lift with the 34 inch tall tires and have it look like the tires are to small...... Should i just got with the 4/2 inch fab tech lift and get those tires, or will it look alright with the 6/3 pro comp lift with the 34 inch tires???
Here is a picture of a 2wd lifted 6/3 inches with 35x12.5's for comparison....
https://www.ford-trucks.com/forums/7...uper-duty.html
Opinions needed please!!!
Stock Tire - 285/75R17 >Search Tires
Section Width: 11.22 in 285 mm
Rim Diameter: 17 in 431.8 mm
Rim Width Range: Unrecognized tire size.
Overall Diameter: 33.83 in 859.28 mm
Sidewall Height: 8.41 in 213.61 mm
Radius: 16.91 in 429.51 mm
Circumference: 106.2 in 2697.4 mm
Revs per Mile: 614.8
