91 F150 XL. Check engine light problems - Ford Truck Enthusiasts Forums
Old 03-08-2010, 12:45 AM
Offroadracer426 Offroadracer426 is offline
Offroadracer426 is starting off with a positive reputation.
Just got a F150, its 1991, runs good but the check engine light will go on and then off then go on then off every 10 minutes. What should i do leave it or buy the code reader?
<input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
Old 03-08-2010, 04:48 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Ford Fuel Injection How To Run a Self-Test Here is a link on how to read the codes without a code reader, however you could buy one for around $30 to make life easier.
Old 03-08-2010, 10:03 AM
Quote:
where could i get a code reader, i was looking online and i saw one for like 100.
Old 03-08-2010, 10:46 AM
Zip Code Select | O'Reilly Auto Parts Have a look here. Might even get one cheaper at wal-mart.
Old 03-08-2010, 12:10 PM
BucksTrucks's Avatar
BucksTrucks BucksTrucks is offline
BucksTrucks is starting off with a positive reputation.
You can pick up a code reader in your desk drawer. A paper clip will get the job done.
Old 03-08-2010, 01:20 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
There's one called the Innova Equus 3145 that a lot of people like (I have one and I recommend it to everyone with an OBD-I Ford). It's much easier and far less error-prone than using the paperclip. I see tons of posts in this forum where people misread their codes or I at least get the feeling they have. The code reader removes all doubt.
Old 03-08-2010, 02:19 PM
SaikotikGunman's Avatar
SaikotikGunman SaikotikGunman is offline
SaikotikGunman is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by andym View Post
There's one called the Innova Equus 3145 that a lot of people like (I have one and I recommend it everyone with an OBD-I Ford). It's much easier and far less error-prone than using the paperclip. I see tons of posts in this forum where people misread their codes or I at least get the feeling they have. The code reader removes all doubt.
Yeah, I'm one of them. Did it five times and pieced together something that made sense.
Old 03-08-2010, 04:26 PM
Quote:
ok, ill try that one out, also, when i push the clutch in the brake goes in a little as well, and theres a little delay in the gas pedal. I'm gonna replace the serpentine belt and get that code reader. Also my friend knows whats causing the delay in gas so he's gonna help me with that and thats about it. my brother said a mount is probably broken and thats causing the brake to go in as well, we have a welder so i'm gonna weld that up. But one problem that i'm most concerned with is it has two gas tanks, the front doesnt work, does anyone know why it might not work or will i just have to mess around with it and figure it out. Thanks for the advice guys, your lots of help.
Old 03-09-2010, 07:54 AM
My guess for the front tank is that the in-tank pump is bad. However check that you have 12v going to it in case the selector switch or wiring is bad.
Old 03-09-2010, 08:45 AM
will do thanks
Brake light ON DASH stays on WyoFlyFisher 1973 - 1979 F-100 & Larger F-Series Trucks 8 12-14-2011 11:25 PM
Backup camera input splitter? AndeyHall Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 6 11-23-2010 10:18 AM
using oil ambyrell1 1997 - 2003 F150 6 08-30-2010 11:47 AM
code 332 maxtruck00 1987 - 1996 F150 & Larger F-Series Trucks 18 06-08-2010 10:38 PM
2005 F150 Airbag Module?? dan291000 2004 - 2008 F150 9 01-15-2010 03:50 PM
Tags
1991, 1996, 3145, 91, 91f150, check, codes, engine, equus, f150, f150xl, ford, light, read, scanner
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
