water pump failure???
#31
Why is Bella dog yelling ? FYI all caps or all bold is yelling.
Mark here is a good paper on pressure read Figure 4. Static and Total Pressure Measurements Within a Dynamic Fluid System
http://www.freescale.com/files/senso...ote/AN1573.pdf
That should get you mind back into high school mode.
To get flow from pressure your going to have to stick a Pitot-Static Tube into
the engine and do a little math with the numbers to get flow.
I don't even know what math formulas to start with. The pilot comes in and says It's Broke Fix It. Anyway you use the same type of setup for pressure and
flow in an exhaust system.
Sean
NOTE : I was just thinking that you could check flow by removing the heater hose and plugging the other
end and dumping it back into the degas with the cap off and you would know that coolant was moving and how fast.
Sean
72CC428
09-26-2016 05:50 PM
peka
20
09-08-2015 11:50 AM
Supercouper
10-05-2009 10:48 PM
