Squeak / Groan on Take Off (96 Ranger) - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 03-07-2010, 06:43 PM
BobLevy BobLevy is offline
BobLevy is starting off with a positive reputation.
Hi, this is my first post and we just bought a '96 Ranger XLT 3.0 5spd 2WD extended cab w/ ~99900 miles.
I have recorded a 10 second video demonstrating it, http://www.youtube.com/watch?v=k6Xk2J4gVDY
Only when taking off from stopped (1st or Reverse), the truck produces a groan / squeak noise for a second or so. If we are excessively gentle taking off, sometimes it won't make the sound. Clutch and transmission work smoothly through all gears.
Anyone know what might cause something like this?
Thanks,
Bob
Old 03-08-2010, 10:45 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
Is the sound inside the cab or external? If inside, it almost sounds like a power brake booster valve that is makes noise as the vacuum is shut off. Or a vacuum line to one of the heater control gizmos. It does not sound mechanical to me, such as a brake drum or rotor. Too quick and soft.
tom
Old 03-09-2010, 07:22 AM
Quote:
tom
Thanks TomW, the noise is external. Standing outside the truck listening to a helper take off, sounds like it's coming from the bottom under the cab maybe.
It's louder from outside than the video portrays.
Old 03-09-2010, 11:30 AM
Rangerman Stan Rangerman Stan is offline
Rangerman Stan is starting off with a positive reputation.
BobLevy, are you still in the process of letting out the clutch when this sound occurrs but still have a little ways to go with the pedal? If so, this sound may be coming from the clutch disc as it gets squeezed by the pressure plate. If a little bit of dust gets imbeded in the disc it can let it slide or slip on the face of the pressure plate or flywheel while other parts of the disc are trying to engage with the flywheel or pressure plate. So while these two things are trying to happen at the same time it produces the noise you hear. (It's some what similar to squeeling the tires when you want to or locking up the brakes in a panic stop. The brakes have stopped the rotation of the tires but the speed of the car makes the tires slide and they squeel when they slip on the pavement.) If it's been a while since you've been into the clutch you may need to replace it or at least have it looked at. My five speed Ranger did the same thing for a while at one point, but I knew the clutch wasn't very old. So I just let it go till I could get to it and it went away on it's own and never came back. Not that I'm recommending doing that, just letting you know what occured with mine. Let us know how it goes.
Old 03-09-2010, 12:18 PM
Quote:
Hi Rangerman Stan. The sound is heard w/in a split second after the clutch pedal is out, gas applied, and the vehicle begins to move. It is heard only when moving from a stop in 1st or Reverse (not during up/down shifts while moving).
My wife (learning to drive a standard) discovered that if we take off by slowly releasing the clutch with no gas applied, it will not produce the sound. So it seems to be produced in some way by the additional torque of applying gas while taking off.
Might that inspire any additional thoughts?
Thanks,
Bob
Old 03-09-2010, 01:48 PM
It's possible the transmission is shifting on its mount, or the engine on its mounts. Another possibility is the U-joints. They can squeak as any internal slack is taken up and the load applied.
Ummmh, can you hang a microphone under the cab to get the full sound effect? Your cell on a string? Someone strapped to the transmission? Heh.
Actually, I would lie on my back and, with eyeglasses of some sort on, inspect the underside of the cab, try to shake the transmission tail housing, cross member and any and all cables that look as if they could move around due to acceleration. The drivetrain will shift to the left as you accelerate, and everything else will try to shift towards the rear... The speedometer cable (if you even have one) will be a different case as it has both motions. Get under, grab and shake...
tom
Dying Cow under the hood... F250_ 1999 - 2003 7.3L Power Stroke Diesel 26 11-09-2014 11:49 PM
How To Fix Pulsating Brakes pawpaw Ranger & B-Series 0 07-08-2014 08:03 PM
Stuck rotors anyone? A/Ox4 1999 to 2016 Super Duty 14 09-04-2012 01:41 AM
Brake groan and squeak normal? B HOOFED 6.7L Power Stroke Diesel 8 01-24-2012 08:31 PM
auto tranny stuck between gear??? gcfisher75 Clutch, Transmission, Differential, Axle & Transfer Case 5 07-25-2004 11:09 PM
Tags
6122, acceleration, brakes, ford, groaning, groans, letting, low, noise, ranger, reverse, sound, speed, squeaking, squeaks, suburban, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
