Accelerator Pedal Position (APP) sensor maintenance w/pics - Ford Truck Enthusiasts Forums
Old 03-07-2010, 05:24 PM
CPUNeck's Avatar
CPUNeck CPUNeck is offline
CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.CPUNeck has a very good reputation on FTE.
Ok, so what do you do on the first 60* day of the year? Something on your TRUCK! Knowing how you guys love pictures, I snapped a few.
While trouble shooting my IDM issues, noticed that my skinny pedal had a "dead" spot just off idle, and decided to investigate... see if I could clean or service it back into specs. The AE was showing a change in voltage, but the engine wasn't responding. So it may in fact be fine, and instead is the chip, don't know. Anyway, here's what I found.
This is the assembly out of the truck. Prior to disassembly, you can see some wear on the fulcrum and also note how the Idle Validation Switch (IVS) is activated.
Here the IVS is removed to show how the lack of lubrication has scored the lever pretty significantly. There was also a fair amount of crusties around the actual switch under the lever, and some yabbies between the potentiometer and pedal assembly.
Here is how I cleaned and lubricated the pivoting points/fulcrums and the products I used. The last shots were the result.
Part numbers on the pedal assembly, and the potentiometer.
Outcome... well unfortunately the "dead" spot appears to still be there, BUT, the pedal is much smoother now in application. Also I believe I may have added some life to my IVS after seeing the condition of the lever. While I cleaned and lubed the assembly, the lube application was minimal as not to attract dust and debris. Hope it helps someone, I still may have to purchase a new one, need to figure out how to test it first.
Old 03-07-2010, 05:34 PM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
Reps for the writeup and pictures! Another project to add to the growing to do list.
Just slightly O/T...whats the highest voltage or % you can get out of the pedal? Mine maxes out around 87%.
Old 03-07-2010, 08:33 PM
Kajtek1's Avatar
Kajtek1 Kajtek1 is offline
Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.Kajtek1 has a very good reputation on FTE.
Nice pictorial. Is this the sensor original for early 99?
Mine was chocking on acceleration last summer, but doesn't do it anymore now.
I wonder if spending $50 for a new one would be good insurance?
Is there other way to control throttle when the sensor goes kaput?
Maybe CC, but the one on my truck died as well.
Old 03-07-2010, 08:43 PM
banjopicker66 banjopicker66 is offline
banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.banjopicker66 has a very good reputation on FTE.
I have a different take on this. My sensor recently went bad; it is the early design also. When I stepped on the go pedal, it wouldn't go unless I "pumped" it a couple of times, just like a carb.
This problem didn't seem that bad until suddenly I was out in an intersection trying to make a turn and it wouldn't respond with on-coming traffic, and that was scary.
I would not recommend attempting a cleaning or repair except as a very temporary measure, but instead replace it as quickly as possible.
Old 03-07-2010, 09:26 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
Always wondered what the IVS looked like. I somehow managed to break the pedal part off my accelerator haha. Need to fix that sometime, but Ford thinks their pedal is worth its weight in gold, just like most other parts.
Old 03-08-2010, 11:51 AM
CPUNeck's Avatar
This is the original APP installed on my truck in September, 1998.
Well in my case, it was acting like debris may have been impacting the "smooth" transition of voltages. No indication there was a short. It responds as designed, but most notably after a small acceleration, if you let off the skinny, you'd have a sharp "jolt" from the drive line caused by "sudden" deceleration. Mind you, I would only be casually letting off the pedal, but it felt like I let the pedal spring back to the up position.
Good news is today it's completely back to normal. I can ease off the throttle, and have the engine "ease" off acceleration! I'm pumped. So, perhaps it took a little bit for the CorrosionX to work its way into the sensor. Definitely a worth while procedure for me. From the looks of the IVS, I'd say in a year I would have rubbed through the lever.
Old 03-08-2010, 12:09 PM
MTDewX's Avatar
MTDewX MTDewX is offline
MTDewX is gaining momentum as a positive member of FTE.MTDewX is gaining momentum as a positive member of FTE.
mine has that dead spot, but only once in a while. nothing like trying to leave a stop sign with no juice, then all of a sudden it wroks and Veerooom. lol
Old 03-08-2010, 12:14 PM
It sure would be great information to know if this is a permanent fix - any updates over the next few months would be appreciated.
I neglected to mention that at times under mild acceleration the transmission would buck and kick. Fellow FTE-ers identified the TPS as the problem.
A known good used one solved the problem right away.
Old 03-08-2010, 12:26 PM
CPUNeck's Avatar
Yep, you can count on it... Just for clarification, under acceleration it really didn't have any problems. I'd have to very gradually depress the pedal to notice the engine wasn't reving, even though I know I was off idle, and voltage was increasing (confirmed by AE.) My biggest indicator was on deceleration. It went from a gradual decline in RPM, to dropping off right before the IVS would activate. The unit seemed pretty tight, but after 10 years and ~250k miles, stuff is going to get in there. We'll see if the CorrisionX managed to "creep" in there, clean and lube a little. I thought the thing would cost over a hundred dollars... for $50, I might have just replaced it... wouldn't have been as much fun though
Old 03-08-2010, 12:33 PM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
PaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputationPaysonPSD has a superb reputation
Excellent write-up and pics. Reps sent.
Old 01-21-2011, 01:41 PM
texasskies12 texasskies12 is offline
texasskies12 is starting off with a positive reputation.
2001 F250 7.3 -- stalls on start
Hi guys,
I am not sure if what is going on with my truck is the same thing you guys are talking about. The truck only has 65K miles and is in pretty good shape. It has always done this but here recently it has good from once every couple of months to many times every 30 minutes. I release the brake and start to accelerate and there is just nothing there. The truck goes forward due to normal idle speeds but there is no response from the vehicle. I think start into a mad dash of stomping on the accelerator and then eventually it will take off. Sometimes up to 3 to 5 seconds. Doesn't sound like much but when you are halfway into an intersection.... Sometimes the Check engine light will come on during the time the engine or accelerator is non responsive...once the truck responds, the light goes away.
Once the truck does this once in a given trip, then it seems to do it more often on that same trip. AND, eventually, the transmission wants to change to third gear right away. OF course this makes for some rough driving because the engine speed is too low for third gear and it tries to go back to second gear...which of course sends it right back to third gear.
This sounds pretty scary to me, like it could need some serious repair but once I restart the engine, it seems to reset and transmission things works out until i start having the unresponsive engine again! Any suggestions? beside drive it into the nearest lake???
Old 01-21-2011, 01:58 PM
PaysonPSD's Avatar
Quote:
Originally Posted by texasskies12 View Post
Hi guys,
Your symptoms sound like the IVS (Idle Validation Switch) has bad or dirty contacts. The IVS contacts are normally open and close when you press on the pedal. If the PCM does not see the contacts close it ignores any signals from the TPS.
1999-2001 have a separate IVS and TPS. 2002-2003 have a combined IVS and TPS.
Old 01-21-2011, 09:40 PM
bfife's Avatar
bfife bfife is offline
still plays with trucks
bfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to beholdbfife is a splendid one to behold
I wish this would be my fix. I have the combo switch. I get a intermitant dead pedal. very exciting when you drive a handshaker. try pulling a 6% grade with and 18K trailer, go for a down shift and have NO THROTTLE. tends to **** you off. Blip the pedal a couple of times and it comes back. I've replace the pedal 3 times in the last yr. 2 OEM pedal and 1 aftermarket. I finally decided it had to be the connector. I cleaned the contacts and used a contact enhancer. thought I had it. 3 days later it does it again. So today I replaced the connector. It dropped out once already. any other ideas? I struggling here.
Barney
Old 01-21-2011, 10:56 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Man, my buddy Barney is going thru mid life truck madness. Sorry Barney, not busting on yaa, just hoping for a relatively easy fix..
Old 01-22-2011, 09:16 AM
01EX 01EX is offline
01EX is gaining momentum as a positive member of FTE.
Thanks for the info
Look at this beauty Diesel_Brad 1999 - 2003 7.3L Power Stroke Diesel 3 08-22-2015 07:22 PM
New Crew Cab Pictures and steering questions Blue_Mongoose 1973 - 1979 F-100 & Larger F-Series Trucks 18 04-30-2012 10:28 PM
D50 Axle shaft U-joints/seals/fluid (PICS) CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 25 03-01-2011 06:24 AM
Front Suspension squeak/creak... does yours? CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 6 06-07-2010 04:30 PM
IDM mod w/pics CPUNeck 1999 - 2003 7.3L Power Stroke Diesel 27 04-25-2010 08:10 PM
Tags
1997, 1999, 2000, 73, acceleration, accelerator, app, diesel, f250, ford, gas, pedal, sensor, switch, throttle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
