Big truck guys, parts on the 'Bay to check out
Here's an option, if I am reading the ad correctly this guy has a rear axle out of Dodge RV with the 5 bolt, 8" circle. You might be able to upgrade the rear axle in your truck and possibly be able to upgrade your front brakes, I don't know if you could use the parts to do it but at this price it worth a try. It's really cheap, IMO, and the seller has the front axle with disc. If you're close it's a steal. The four wheels and tires are worth the price.
Complete Dana 70 HD Rear End 4.56 Ratio : eBay Motors (item 140348849097 end time Mar-26-10 20:48:36 PDT)
If it weren't so far way I'd grap it in a second.
Early IH trucks had a five bolt pattern rear end that could be swap under our old Ford. I was next to a '50 F-5 at a truck that had one. Right next to it was an early '70 IH, owned by the same guy, that had the same axle. The F-5 owner told me the IH rear axle has the same gears as the early '70s Ford axle and could be swapped to higher gears.
52' fordnut
03-04-2013 08:02 PM
mainefrenchman
35
02-16-2011 12:04 PM
J1MMY
02-06-2009 07:28 AM
bluestang65
11-25-2008 04:01 PM
99ranger4x4
01-25-2006 09:14 PM
