Steering Wander/sloppiness... - Ford Truck Enthusiasts Forums
Old 03-06-2010, 10:17 PM
schlepprock250's Avatar
schlepprock250 schlepprock250 is offline
Guns Dont Kill People..
schlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to beholdschlepprock250 is a splendid one to behold
OK guys,i know search is my friend,but you guys are too....LOL. My truck with 199000 on the clock,drives awful while on the highway,lets say,you have to kinda"float" the steering wheel back and forth(usually very little)to keep it straight in your lane,ok,when your floating the wheel one way to keep it tracking in the lane,and you have to float it the other way,you go a little and there is no response,you go a little more and it veers back that direction,not violently but not very comfortable to drive either.While turning it one direction and you hit a sorta hard spot and you have to put a little more pressure to get past it,then its like it goes too far.I noticed it more while on our trip to Daytona this week pulling a trailer,but you dont have to be pulling to feel it.....thoughts...?
Old 03-06-2010, 10:24 PM
Bigcat350's Avatar
Bigcat350 Bigcat350 is offline
Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.Bigcat350 has a very good reputation on FTE.
Phil have you tried the cheap and easy adjustment yet. I have done it on 2 SD and it really helps.
Old 03-06-2010, 10:33 PM
Texas Outlaw's Avatar
Texas Outlaw Texas Outlaw is offline
Not a liberal...
Texas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant futureTexas Outlaw has a brilliant future
Check the pitman arm and make sure it's tight. Also the drag link and tie rod ends. ball joints could also be suspect.
In regards to the steering box adjustment, meh, I don't reccomend it. It works great if the problem is in the steering box gear lash. If it isn't, you end up with a truck that wanders and is more difficult to correct beacuse the box is too tight. I know from experience and it sucks.
I had this problem three years ago and it turned out to be a worn pitman arm and bad tie rod ends.
Old 03-06-2010, 10:34 PM
Whats that Eddie?It's something thats either just starting,or something thats been progressively getting worse,we've just started noticing it within the last couple of weeks.
Old 03-06-2010, 10:36 PM
Bigcat350's Avatar
Very true Scott if some thing else is worn out this adjustment will make it drive worse.
Old 03-06-2010, 10:38 PM
By the way guys,i am searching as we speak,i was just wondering if anyone had figured a more than likely cause/fix.
Old 03-06-2010, 10:47 PM
Another thought is it doesn't wobble or get worse with bumps/potholes.
Old 03-06-2010, 10:49 PM
F350-6's Avatar
F350-6 F350-6 is offline
F350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputationF350-6 has a superb reputation
When mine did that I just needed a 1/4 turn on the steering box to fix it. Of course it took me over 300,000 miles to develop slop in the box so I'd suggest you check the stuff Scott mentioned first.
Old 03-06-2010, 11:02 PM
Again,maybe i wasn't clear before,it's like it has a burr or something,while turning,you can feel it get to a certain point that it tightens up,you have to put a little more turning pressure to it,then it kinda falls over/past this"burr" and gets loose again.Only it's not just while turning,it's while driving straight/just trying to keep it in your lane.
Old 03-06-2010, 11:08 PM
bc2sv bc2sv is offline
bc2sv is starting off with a positive reputation.
What is the simptoms of pitman arm wear? It's amasing how you get used to the way your truck drives and don't notice a thing, but when I went in for a check of my starter engaging problem the local diesel guy said "looks like is time for a pitman arm" WTF? What can wear out? And it looks like something one can easily change out , but why?
Old 03-06-2010, 11:37 PM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
Ball joints for me. Replaced mine and it helped alot. There is still a slight play in the wheel but what I have read thats normal for these trucks.
Old 03-07-2010, 12:43 PM
Not a liberal...
Quote:
The hole in the pitman arm can wear and over time it becomes wallowed out. This translates into sloppy steering that can be mistaken for excessive lash in the steering gear.
Been there too....ha ha.
Old 03-07-2010, 10:34 PM
Thanks for the info... my BS meter goes up every time I get a suggestion like this. Any way you know of to actually know if this fix is needed?
Old 03-07-2010, 11:03 PM
big poppa's Avatar
big poppa big poppa is offline
big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.big poppa has a spectacular reputation.
Man Scott, thats good, woulda never guessed.. I constantly have to adjust the steering in mine, was going to tighten up a smidge in the gear box first but now this got me wondering, subscribing Phil...
Old 03-08-2010, 02:03 AM
2000ca250 2000ca250 is offline
2000ca250 has a good reputation on FTE.2000ca250 has a good reputation on FTE.
i had very minor "wandering" when I first got my truck, and since i eventually plan on lifting it and throwin bigger tires on it just went ahead of got a dual steering stabilizer set up. Put it on and no more wandering...not sure if this is a cure but it definitely made a noticible difference for me, and i'm only running 285/75/16's
Firestone Riderite airbags causing sway? (LONG) schlepprock250 1999 - 2003 7.3L Power Stroke Diesel 37 11-17-2014 12:06 PM
All new front end stuff...still doesn't handle right! custom1106 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 30 09-07-2012 12:58 PM
Steering float mlis 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 07-02-2012 11:27 PM
Coil Conversion 7.3 Ex Excursion - King of SUVs 1 06-18-2009 10:21 AM
2003 EB 4x4 LOOSE STEERING Razzmaniac 1997-2006 Expedition & Navigator 10 10-17-2006 12:43 AM
Tags
2002, clunking, end, f150, f250, ford, front, highway, noise, stabilizer, steering, truck, wander, wanders, wanding
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
