What water temps are you guys running at?
on
Not necessarily. I'll run 180 during this time of year with 20-30 ambient temp, however, I do run hotter then "your" stock or just tuned truck, so you should keep that in mind. It'll get hotter if I'm blowing down the interstate at 80-85 though.
Did you replace your thermostat when you did your flush? Or after you ran it without coolant? It has to be pretty cold outside (like below freezing) for me to run as low as 160. And I think my thermostat needs replaced.
I'm thinking maybe running it without coolant damaged your thermostat.
Does this look like the right part? I think it may come with the O ring too.
Item Detail | O'Reilly Auto Parts
Yea I like going to OReilys. They seam to always have what I need and they have good prices too. And there is one three blocks from where I work. So getting there at lunch is easy.
