KZ Stonridge 5th wheels
#61
Received 5,132 Likes
on
#62
#64
#65
Plenty of tickets are still available, if anyone is interested in coming.
As to genset installs, the prep is pretty easy if you can wire. You do need to line the generator compartment with sheet metal to close it off from the rig, but none of it is complicated.
Steve
#66
it does come with it if you like, the one we bought, on the lot, came with every other bell and wistle but that. So most likely I will just buy one and hook up the cord to it.
Got my 18K Reese slider installed today. Nice...it is a hidden system so the only thing that will be left in the bed is the four holes that the hitch passes thru the bed into the mounting system.
Got the in-bed plug mounted as well. I place that in the left rear, just after the wheel wheel and just ahead of the Ford Cable lock that I have mounted in place of the tie down hook.
Will take some pics of everything probably Sat, as I will be busy tomorrow with taking my old unit in and getting the 5er on the road tomorrow....somewhere in there I am suppose to be at work.
#67
Got the in-bed plug mounted as well. I place that in the right rear, just after the wheel wheel and just ahead of the Ford Cable lock that I have mounted in place of the tie down hook.
Steve
#68
where do you think 50 % of the good year marathon's are made? Yup, you guessed it, CHINA my 2009 Bighorn 3055 came with Goodyear marathon tires, stamped MADE IN CHINA,WTF oh well, I don't have an extra $1200 laying around, so its max air pressure & hope for the best.
#69
I don't know what the answer is. As long as price drives decisions, someone will always be looking for a way to do it cheaper. It's not just tires. It's every darn thing. I work on stuff that used to last well over a decade. Now if it makes it through the warranty period, you're lucky. I am sure it is the same for everybody.
Steve
Steve
#70
on
#71
So will you be in Bristol this coming week? The concessionaires are arriving and the early birds are starting to arrive in the holding areas. My life is just about to jump into overdrive for a week. Then, just as suddenly as it starts, the morning after the race, everyone is gone.
Steve
Steve
I wish I could make Bristol. That is one race that I "will" make in my lifetime. I am waiting on Texas for now. Will be there on the 10th for the race on the 18th of April.
As to Genset install, besides the sheet metal, do you put insulation on the compartment walls to dead out some of the noise and vibration?
The rig Senix has just acquired would be sweet at a NASCAR race.
#72
Not hijacking the thread!
And yes, his rig would be sweet at NASCAR.
Steve
#73
on
#74
I had one of those once, never used it. Was a little concerned about CO (being heavier that air) laying on the roof and getting into a roof vent, if it happened to be open. I made one that lays on the ground so I can move it away from tents or other neighbors as needed when at a race.
#75
Steve
