Help with year.....
Help with year.....
I have been told my F150 is a 1977, but there are a few things that point to it being a 1966....can anyone tell me off the following numbers:
7A86G130801084908 or F14SC084908, I got these off the NZ rego form, if they are wrong, I will go look at the ID tag.
Cheers, Shane
Cheers, Shane
7A86G130801084908 or F14SCO84908, I got these off the NZ rego form, if they are wrong, I will go look at the ID tag.
Cheers, Shane
Cheers, Shane
S = 400 2V
C = Oakville, Ontario Canada Assembly Plant
O84908 = 1977 Numerical Sequence of Assembly (Serial Number)
VIN Numbers and Codes
Not too sure what all this is but here goes
VIN Plate (Metal on Driver's Door)
F10BLDJ5021
WB 117
Color V
Type/GVW F101
Body AT3
Trans C
Axil M3
1979 42
Other Info (Sticker on Driver's Door Jamb)
Only listing what is not obvious
After the VIN there is a number F0243
Type: Truck T0744
Says Truck was mfg'd 11/78
Thanks
F10BLDJ5021
WB 117
Color V
Type/GVW F101
Body AT3
Trans C
Axil M3
1979 42
Type: Truck T0744
Thanks
Cheers, Shane
Cheers, Shane
There are more than a few things that differentiate a 66 from a 77. They are complete different bodies. Did you make a typo and mean 76?
on
1 Post
B - 300 1v
L - Michigan truck plant
DJ5021 - November 1978 sequential build
117 - 117 inch wheel base (regular cab, short bed)
V - Medium Chestnut Metallic
F101 - F100 2WD, 4800 lbs GVW
AT3 - AT = Sand all vinyl. 3 = Custom with Flareside box.
C - 3 speed manual tranny, Ford 3.03 AKA "Three on Tree".
M3? This isn't valid - please check again.
1979 - model year
42 - Cleveland, Ohio district sales office
Most 1965/72 and all 1973/79 Crew Cabs were assembled in Canada, most were sold in the US of A.
I've decoded VIN's of Canadian assembled trucks, but...by their DSO codes, these were ordered from Atlanta GA and Pittsburgh PA.
Look on the Warranty Plate for the DSO code, post what it is.
F10 - F100 2WD
B - 300 1v
1979 - model year
B - 300 1v
1979 - model year
Thanks for the help.
Tom
Cheers, Shane
Cheers, Shane
Tom
Do you know what city the Michigan Truck Plant is in?
It was in Dearborn (The Rouge). Where it is today, I dunno, as Ford built a new Michigan plant several years ago.
I could not find the Medium Chestnut Metallic on the Ford Truck Color list.
What Ford Truck Color list would that be?
It's listed in the 1973/79 Ford Light Truck Parts Catalog and in the 1973/79 Ford Passenger Car Parts Catalog.
Would the interior paint have been the same color? I need to restore the dash to the original color.
The BODY code is AT3: A = Upholstery color = Sand all Vinyl // T = Dash color = Sand // 3 = Custom, with FLARESIDE box.
And I guess Flareside = Stepside NOT! A Stepside is a Chevrolet.
The metal Warranty Plate is riveted on the left door face below the latch.
The white Safety Standard's Certification Label is glued onto the door face or glued onto the B pillar, below the striker plate.
