You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I have this narrowed down now but I'm needing someone good at electrical systems to help me out.
I'm completely stumped and could probably find it given time, but I don't have much time before I need to move. Top that off with just being laid off, and money is an issue too.
Anyone that has a wiring diagram I'd really appreciate the help!
See my other post in the main PSD forum for 4.5amp electrical draw.
__________________
2001 PSD 4x4 CC, SB, 7.3l Bilstein shocks, 182K miles and counting. Open air (K&N type) filter, nitto grappler 315/75/16 tires, mag hytec trans-pan and rear diff cover. DP tuner and stage 2 Rosewood DIY injectors.
New to me as of 1/17/10.
No help?
Anyone know of a good auto electric place to take this then? I was just laid off and was hoping to figure this out myself but am unable to get to the bottom of it.
If you know of anyone/anyplace please PM me.
Thanks
CrazyKen
__________________
simplest way is to pull all the fuses and hook up your multi meter in each one set on amps when you find the draw see what that fuse is for (listed in the owners manual) most common are lights in sun visors (bad mercury switch)
__________________ They promise freedom, but they themselves are slaves of sin and corruption. For you are a slave to whatever controls you.
the little people who live behind my eyes and scream directly at my brain told me to tell you HELLO Diamond K your complete automotive and truck repair center
I wish it was just one fuse! If I pull 5 fuses I can get the draw to stop. (I have put the multimeter in line between power supply and power distribution box.)
Any one of the 5 in place will start the draw again. Strange!!
__________________
you have to check how much draw, there are keep alive circuits for the pcm, the radio maybe the gem. these are low draws. you need to look for a large draw if you are having battery issues. the alternator can suck a battery down if the diode bridge is bad, an alternator usually is a large draw
I used to mechanic but never dealt much with electrical problem, I'm really not that great at that part of it.
Not sure where to even look now. When I pull the alternator out of the ciruit (disconnect) I still have the draw. It is always close to 4.5 amps.
I've checked over the entire harness, even have the inner fender out to get to stuff easier. Everything appears to be in good shape, no chaffing, cut wiring, burned, etc.
I think I'm actually going to have to throw in the towel and figure out how to pay someone to do this for me.
I don't like conceding. I haven't had anyone touch on of my cars/trucks in years, but don't feel like I have any options right now.
__________________
Has anyone ever had a draw this big before?
I've checked anywhere that I could find in other posts but nothing seems wrong with the wiring.
I really need to get this up and running again. I just let my other car go and this has to be my daily driver now.
__________________
Ok, so here is my new findings.
I had the power completely disconnected from the distribution box and it still pulled the batteries down.
Anybody know what would be inline before the distribution box? I believe that narrowed it way down but the only way to know without the wiring diagram would be for me to start chasing wires.
I think it gave me a new starting point though. I just can't figure out what would have drained the batteries with everything disconnected that way.
__________________
starter solenoid not opening all the way? just a wag!
