SCT SF3 adjustmentment options? - Ford Truck Enthusiasts Forums
Old 03-05-2010, 01:07 PM
YoungMT Hick's Avatar
YoungMT Hick YoungMT Hick is offline
YoungMT Hick is starting off with a positive reputation.
I have an SCT SF3 for a 2006 F350 6.0. I normally run the street tune and the only adjustments i change are the tire size as in revs per mile and thats about all but there is like shift press from gear to gear, and like wot from gear to gear. was wondering if there is anyone out there that knows a good way to set that stuff. I dont know what to adjust or how far. So if someone can help i would appreciate that. Truck is 2006 f350, 37" tires 6" lift and 3.73 gears. thanks
Old 03-05-2010, 01:11 PM
ehgeeray ehgeeray is offline
ehgeeray is gaining momentum as a positive member of FTE.
Quote:
You need to purchase custom tunes. you can have someone set up tunes files to match your truck... It will run WAY better.
Old 03-05-2010, 03:27 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
I run WOT shift pressures +10% on certain files. If you have a specific problem, it's best that you have your tuner make the adjustments. I've been told not to mess with shift points at all.
Old 03-06-2010, 12:07 AM
Ya i know i can get custom tunes. but this is a sf3 not the x3 so i dont know how the custom tunes go if they are any different. i can run the wot 10% but what other adjustments can i run and where can i get tunes from for this? thanks
Old 03-06-2010, 05:03 PM
Jayybird Jayybird is offline
Jayybird is starting off with a positive reputation.
SCTX3
Fellas,
Quick question. I just bought a SCT X3 tuner. What are the "srategy tunes" that are already on the tuner? Are these preloaded tunes..? I am not real familar with this thing yet. However, I am not too interested in this since i bought a few custom tunes. But I would like to understand the full functionality of the tuner. Any input would be greatly appreciated.
Old 03-31-2010, 07:37 PM
PETE'S_6.0PSD PETE'S_6.0PSD is offline
PETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to allPETE'S_6.0PSD is a name known to all
the preloaded tunes are canned tunes and will work with any strategy, and might shift good or not. and they might lock your TC or not. anyways get a custom file and be done with it. you will never go back.
Old 03-31-2010, 08:16 PM
toolman05kr toolman05kr is offline
toolman05kr is gaining momentum as a positive member of FTE.
Quote:
Yep, what Pete said.
Old 03-31-2010, 08:22 PM
04F-250mark's Avatar
04F-250mark 04F-250mark is offline
04F-250mark is starting off with a positive reputation.
No doubt!! CUSTOM!! They ask what you got and what do you want to do and then it is pure FUN!!
For Sale SCT#3015 Iolabowhunter Texas Chapter 1 12-07-2015 07:04 AM
SCT sf3 V10 with 5 tunes TakeItEasy Ford Truck Parts for Sale 3 10-03-2014 11:20 AM
Monitoring EGT w/ SCT SF3 tuner olfordsnstone 6.0L Power Stroke Diesel 6 06-14-2013 11:43 PM
sct vs edge dhag911 6.0L Power Stroke Diesel 29 06-08-2012 08:51 AM
Question about using SCT SF3 as code reader TexasA&M 6.0L Power Stroke Diesel 3 02-11-2011 03:04 PM
Tags
03, f350, ford, options, preloaded, pressures, reviews, sct, sf3, shift, size, tire, tunes, wot, x3
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
