Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-05-2010, 11:42 AM
kupaa's Avatar
kupaa kupaa is offline
Garage is empty, add now
kupaa is gaining momentum as a positive member of FTE.
wvo
someone is selling wvo filtered to 1 micron if i run this do i have to filter it more or can i just mix it with diesel?
__________________
2002 SC SB 4X4,6637,STRAIGHT PIPE,COBALT GAUGES,ITP OBA,REGULATED RETURN,HPX,AIH DELETE,BUILT TRANS,BILLET SHAFT AND CONVERTER,DP TUNER F6 LIVE TUNED BY JODY, GTP38R,CASSERLY 200CC 80% HYBRIDS,TERMINATED,20X10 XD,ATZ 35/12.50/20
468 HP 970 ft lbs
CHRIS
  #2 (permalink)
Old 03-05-2010, 09:05 PM
TurnerBioDiesel's Avatar
TurnerBioDiesel TurnerBioDiesel is offline
2003 Ford Excursion
TurnerBioDiesel is starting off with a positive reputation.
1 micron is very good. No extra filtering is needed. Mix away.
  #3 (permalink)
Old 03-06-2010, 09:26 AM
Rushmore X's Avatar
Rushmore X Rushmore X is offline
2003 Ford Excursion
Rushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to beholdRushmore X is a splendid one to behold
I filter to 1 micron using sock filters. How fine is the OEM Fuel filter?
__________________
Trent - 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, 6637 intake mod, 4" MBRP w/ 5" tip, DP tuner, IH up-pipes, redhead steering box, 6.0 trans cooler, ISSPRO & Aeroforce gauges in A-pillar, Wicked Wheel, "Bullet Proof" Transmission rebuilt by Rapid Diesel, extra leaf spring added all around, more to follow! Gone BIO!!!
2002 TDI New Beetle - also likes Bio.
  #4 (permalink)
Old 03-06-2010, 06:09 PM
2003 Ford Excursion
Also remember just because its filtered to 1 micron dont mean its dewatered. Ask them how its filtered and dewatered. Centrifuge will flash off some water if heated.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
