Location of horn relay
Old 03-05-2010, 11:26 AM
Charrlie_S's Avatar
Charrlie_S
Charrlie_S is offline
1989 F-150 4 wheel drive, with cruise control, 4.9 six cylinder. Can't find the horn relay. All my other sources say mounted to the cruise control amplifier bracket. Not there on this truck. Can someone help? Thanks.
Charrlie_S
Old 03-05-2010, 02:57 PM
THE BLUE HEAP's Avatar
THE BLUE HEAP
THE BLUE HEAP is offline
Hi,
Acording to my 1986 Ford shop manual its located under the instrument panel to the left of the steering column & is mounted on the outboard attaching screw of the speed control amplifier module.
Hope this helps
Old 03-05-2010, 03:37 PM
subford's Avatar
subford
subford is offline
The horn relay is located on the Right Hand side of the IP near the Hazard Flasher & glove box.
It is at location C-1 in the diagram below:
Old 03-05-2010, 04:04 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Here is a picture of the horn relay in my '87. It's at the top end of the two yellow wires. The bundle is the cruise control vacuum line and wiring pass-through in the firewall, with the top of the throttle pedal also in view. I have no idea how many years they put it in this location.
Old 03-05-2010, 04:09 PM
subford's Avatar
subford
subford is offline
The 1989 & 1990 shop manuals say it is over by the glove box as in the diagram above.
Old 03-05-2010, 05:25 PM
Charrlie_S's Avatar
Charrlie_S
Originally Posted by THE BLUE HEAP
Hi,
Hope this helps
That is what Alldata, said also, but on this vehicle the cruise amplifier is to the right of the steering column. Almost to the center of the dash.
Thanks to subford, his component diag showed me the correct location. Behind the glove box, almost down in the kick panel.
Thanks to everyone for their help.
Charrlie_S
Old 04-02-2016, 09:38 AM
Barry B.'s Avatar
Barry B.
Barry B. is offline
I have a 1986 with cruise control and can't locate the horn relay anywhere. My truck originally had cruise control, previous owner had steering column problems and horn didn't work so he ran a line to the horns and mounted a push switch on the dash, now that doesn't work either. I found a disconnected dark blue wire near the horn and reconnected it, it worked but a few minutes later it did not work, this is driving me nuts, I want the horns to work and is required to pass the state safety test. I could forget about using the cruise control just want to be able to toot the horn when needed, just want to know the best way to get a horn , thanks, Barry
Thoth88
10-31-2017 07:02 AM
biggdirty7.3
02-02-2017 10:13 PM
nailerdog
34
01-31-2017 09:02 PM
Gary Newberry
1978 - 1996 Big Bronco
01-21-2017 04:36 PM
rwrogers
1999 to 2016 Super Duty
09-08-2016 04:57 PM
Quick Reply: Location of horn relay
