Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 03-04-2010, 07:31 PM
desertt5 desertt5 is offline
2003 Ford Excursion
desertt5 is starting off with a positive reputation.
Rear brakes
Do the rear caliper just compress in with a c-clamp or do they have to be turned in like on the Mustang? helping a friend with his 08 tomorrow.
__________________
03 Ex Limited 6.0 4x4
09 KZ Spree 289KS
Semper Fi
  #2 (permalink)
Old 03-04-2010, 08:04 PM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
1. Check the brake fluid level in the brake master cylinder reservoir.
o If required, remove the fluid until the brake master cylinder reservoir is half full.
2. Remove the wheel and tire.
3. CAUTION: Do not allow the brake caliper to hang by the flexible brake hose or damage to the hose may occur. Remove the 2 brake caliper guide pin caps and bolts and position the caliper and brake pad assembly aside.
o Support the caliper using mechanic's wire.
o Remove and discard the guide pin bushings.
o Inspect the guide pin threads for damage, install new guide pin(s) as necessary.
4. Remove the brake pads from the caliper.
5. Inspect the brake pads for wear or contamination and install new pads as necessary.
6. Using a suitable clamp, press the piston into the caliper.
7. Inspect the brake disc and resurface or install a new brake disc as necessary.
Installation
1. Clean, dry and inspect the brake caliper anchor plate. Apply equal amounts of the supplied yellow lubricant to the 4 brake pad contact points on the anchor plate as shown.
2. CAUTION: Do not apply lubricant to guide pin threads or incorrect tightening of the guide pins may result. Install new brake hardware as follows:
o Apply equal amounts of the supplied white lubricant to the inside of the guide pin bushings.
o Install the guide pin bushings into the caliper bores.
o Install the guide pins into the bushings.
3. Install the brake pads to the caliper.
4. Position the caliper onto the anchor plate and install the 2 brake caliper guide pin bolts.
o To install, tighten to 38 Nm (28 lb-ft).
o Clean and dry guide pin threads as necessary.
5. Install the wheel and tire.
6. Apply the brake several times to verify correct brake operation.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 03-05-2010, 09:15 AM
2003 Ford Excursion
That's waht I was looking for. Thanks
__________________
09 KZ Spree 289KS
Semper Fi
  #4 (permalink)
Old 05-19-2010, 09:28 AM
MikeSTGL MikeSTGL is offline
MikeSTGL is starting off with a positive reputation.
Are the caliber bolts on the frount and rear a special size ? I looked at them this weekend and they look tike a hex ( allen ) but the sets I had did not fit . Could they be a size that doe not come in the standard sets that someone would buy. Like a standard metric set comes with a 8mm and 10 mm but no 9 mm.
Thanks.
Tags
07, 2007, brake, brakes, caliper, compressing, expedatition, expedition, ford, forums, guide, lincoln, navigator, pin, pins, rear
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
