Squeaky Front Shock!!!! - Ford Truck Enthusiasts Forums
Old 03-04-2010, 06:57 PM
jwillyf150's Avatar
jwillyf150 jwillyf150 is offline
jwillyf150 is starting off with a positive reputation.
Does anybody have any suggestions on how to stop a squeaking front shock. It's my drivers side front shock only. The shocks are fine as far as wear and ride, it's just this squeaking (very noticable in parking lots) thats about to drive me crazy!! Thanks for replies..
Old 03-04-2010, 08:45 PM
jwillyf150's Avatar
Anybody???
Old 03-04-2010, 10:07 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
I think you'd have to replace the shock.....
Old 03-05-2010, 04:21 AM
magnet1's Avatar
magnet1 magnet1 is offline
magnet1 is starting off with a positive reputation.
I am glad to see I am not alone. I couldn't tell if it was my steering or suspension, But its definitely my shocks. I even went underneath and lubed all the rubber bushings with Kroil, Hoping it would solve the annoying noise; But its still there. I only have 34,000 on my truck, So I am not ready to put new shocks on yet.
Old 03-05-2010, 05:31 AM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
I do not believe that is is the shock. I would look at pivot points of the suspension as the source of the squeak. Have you had someone bounce the truck while parked and you listen to the area?
Old 03-06-2010, 07:16 PM
1BADGRL 1BADGRL is offline
1BADGRL is starting off with a positive reputation.
I have an 06 F150 Supercrew... Changed the shocks at around 72k (Bilstiens) and I have the squeak you described. Its driving me crazy. Its NOT THE SHOCKS. If anyone has any ideas I'd love to hear them.
Old 03-06-2010, 07:18 PM
Ryan50hrl's Avatar
sway bar bushings???
Old 03-06-2010, 07:26 PM
Hmm... Will check it out. It's a really high pitched squeak like metal on metal. Almost sounds like it's coming from the hub.
Old 03-06-2010, 07:48 PM
NASSTY's Avatar
NASSTY NASSTY is offline
NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.NASSTY has a great reputation on FTE.
Quote:
Could be? Or maybe a tie rod end?
Old 03-06-2010, 09:29 PM
magnet1's Avatar
Yeah, I really notice mine when I am pulling out of the garage. When I put it in gear and step on the gas; Just before the truck moves it gives that "bathtub" squeak. That little bit of initial torque must effect the suspension somewhere. I know its not in the steering. It also does it when you have an extreme rise and drop in the road. I lubed every joint I could find, And still hear it.
Old 03-07-2010, 11:44 AM
jwillyf150's Avatar
I have lubed everything also and it still squeaks a little just not as loud. It's really getting annoying.
Old 03-07-2010, 06:02 PM
wolf189's Avatar
wolf189 wolf189 is offline
wolf189 has a great reputation on FTE.wolf189 has a great reputation on FTE.wolf189 has a great reputation on FTE.wolf189 has a great reputation on FTE.wolf189 has a great reputation on FTE.
Quote:
Originally Posted by jwillyf150 View Post
Anybody???
ummm... turn the stereo up?
...that was what someone suggested to me once some years back when i was trying to figure out what to do about a similar mysterious creak coming from the front of the '93 F-150 I had at the time. never did figure it out before finally selling the truck. hopefully you have better luck than i did.
Old 03-07-2010, 06:45 PM
Smokey01's Avatar
Smokey01 Smokey01 is offline
Smokey01 is starting off with a positive reputation.
I have ran into this problem before with the sqeeking....ball joints was my problem
Old 03-07-2010, 07:29 PM
NASSTY's Avatar
How did you lube the non-greasable ball joints and tie rod ends?
Old 03-07-2010, 09:41 PM
jwillyf150's Avatar
No but did notice a tear in the lower ball joint boot. The squeak kinda sounds like it may be coming from this location. Maybe I can shoot some grease in this cut for temporary fix dunno?
02 Explorer Front end Squeak nascar_20 Explorer, Sport Trac, Mountaineer & Aviator 4 11-15-2013 06:35 AM
Shocks for lifted truck 9902ford 1997 - 2003 F150 2 07-22-2013 02:43 PM
front end squeak.... Gwilkrrs 6.4L Power Stroke Diesel 12 06-26-2012 08:00 AM
Squeaky truck mikecox1 1997-2006 Expedition & Navigator 4 09-19-2008 12:49 PM
Rear shock squeak goatdriver 2004 - 2008 F150 4 06-03-2007 07:47 PM
Tags
2001, ball, f150, fix, ford, joints, loud, lube, shock, shocks, squeaking, squeaky, squeeks, squeeky, stop, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
