Gas running back to tank when sitting
Received 5,131 Likes
on
on
This is a real common "problem". An electric pump near the tank is the usual solution. If it happens in a matter of hours there may be a small leak in a connection that is letting air in.
I am ready to throw this one in the junk pile. Hope you have better luck.
Check your line connection at the tank first. My 56 behind the seat tank would do the same thing. However, I traced it down to the "nut" that holds the flared line in the top of the tank. tank. I fixed it by using Rector Seal paste thread sealant (with teflon in it) on the treads and it cured the problem.
You should check each connection in the fuel line for tightness all the way to the carb as well. Sometimes just losening the clamps and repositioning them will fix the problem. But if it is a screw together flared fitting ANYWHERE use the Teflon paste thread sealer. It worked for me.
I pulled a Holley off for this Edelbrock. I like the Holley's much better, but it had a leak in the secondary diaphragm. There are different diaphragms available for that carb, all with different specs. I couldn't get an answer about which one I needed and I had bought the Edelbrock for a project that sold, so I swapped 'em out.
I have the same carb and the same problem. If it sets 3 days, you have to crank on it until it fills back up with gas. I think it is leaking out into the engine. I bought it new and I think it is a piece of junk. Runs too rich, bought the kit to re jet it, put in smaller jets and changed metering rods per the instructions. No effect at all. Called Edelbrock and they say float level to high. I checked and it was correct, later took it to a mechanic and he checked it also. Then they claimed fuel pressure too high, so I put on a regulator and set the pressure at 4 psi as they recommended. No change. I have talked to probably 20 people with this carb. About half of them have the same problems and the other half are very happy. Apparently there is a big difference from carb to carb.
.....Then they claimed fuel pressure too high, so I put on a regulator and set the pressure at 4 psi as they recommended. No change. I have talked to probably 20 people with this carb. About half of them have the same problems and the other half are very happy. Apparently there is a big difference from carb to carb.
Holley Performance Products Two Port 4.5-9 PSI *12-704
I had an Edelbrock carb on a 460 for almost 8 yrs and never had a problem, never leaked a drop either. Few Holleys can claim that
Unless the fuel pump is bad, the gas can't run back to the tank. You can check it by disconnecting the fuel line between the tank and the fuel pump, plug the line from the tank and install a temp line from the inlet of the fuel pump thru a hole in the top of a glass jar. If it is really leaking back, there will be gas in the jar after a short time. If there is I'd suspect the check ***** in the fuel pump are sticking. The typical reason for a carb going dry when sitting is dried and shrunken carb gaskets allowing the gas to evaporate or leak into the engine or onto the ground. Pull out the dipstick and take a good whiff of it. Does it smell like raw gas? Does the oil level increase? Do you smell gas when you first open the hood or when parked inside a garage? The fact you stated that you had this carb sitting around for a while leads me to suspect the gaskets.
One more possibility is an unvented fuel tank is forming a vacuum pulling the fuel back.
