gas tank how do i know if I have EEC - Ford Truck Enthusiasts Forums
Old 03-04-2010, 02:17 AM
spudgunman's Avatar
spudgunman spudgunman is offline
spudgunman is starting off with a positive reputation.
finally have the cash for a new 38g tank from LMC question how do i know if I have EEC or not?
Old 03-04-2010, 04:01 AM
TexasTrash's Avatar
TexasTrash TexasTrash is offline
TexasTrash is starting off with a positive reputation.
Good question, I would like to know this as well!
Old 03-04-2010, 05:17 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
EEC: Electronic Engine Control system. Vehicles with this setup have an onboard computer.
The only 1970's vehicles to have EEC: 1979 LTD's & Mercury Grand Marquis sold new in CA with a 351W.
Old 03-04-2010, 11:36 AM
Shane in WI Shane in WI is offline
Shane in WI is starting off with a positive reputation.
I am not sure if this is right, and don't want to contradict Numberdummy, but would hate to see someone order the wrong tank. I just bought a new tank for my 77 F100 and my understaning is that EEC is Electronic Emission Control which is a hole in the top of the tank which connects by fuel line along the right side frame rail to a canister in the engine bay. Some tanks have this hole and some don't. The information I have read list the tank with the vent pipe to the front of the truck with EEC and to the rear without it. Both my 77 and the 75 parts truck used the same tank with the top vent hole.
Shane
Old 03-04-2010, 01:17 PM
Quote:
I just bought a new tank for my 77 F100 and my understanding is that EEC is Electronic Emission Control which is a hole in the top of the tank which connects by fuel line along the right side frame rail to a canister in the engine bay.
This is known as the EVAPORATIVE EMISSION system!
(sigh)
The EVAPORATIVE EMISSION system (there is no FoMoCo abbreviation for it other than "Evap" Emission) is NOT the same as EEC = ELECTRONIC EMISSION CONTROL system, which uses an onboard computer.
EEC was used in two 1979 passenger cars w/351W's sold new in CA only.
Evaporative Emission (it's not electronic!) was introduced in 1970. With evaporative emission, you have, depending on if you have dual tanks or not: One or two fuel vapor valves, and...
A charcoal cannister, a crankcase filter...that clips into the aircleaner. A corrogated paper hose (D4ZZ9D667A) routes from the cannister to this filter.
Plus, there are other assorted hoses and misc. scheiss.
The fuel tanks used with Evaporative Emission are not the same without Evaporative Emission, which, btw was also used in Passenger Cars, Bronco's and Econolines.
Add Rangers, Bronco II's and etc in the 1980's.
I was a Ford partsman for 35 years (from 1962 thru 1997), so I know what the hell the difference is betwen EEC and Evaporative Emission.
The problem is...the beetle brained pinheads at LMC do not know the difference, since they use the abbreviation of EEC for EVAPORATIVE EMISSION!
Old 03-04-2010, 03:45 PM
spudgunman's Avatar
so if I dont care about emissions and obviously dont have electric control I order with out.. correct.
Old 03-04-2010, 04:22 PM
Thanks for straightening us out Bill. I was going by what I read about tanks which stated EEC. I read the "Electronic Emission Control" right off a gas tank add on ebay which was wrong. Having just gone thru researching and ordering a new tank for my truck, I figured he was asking about the extra hole in the top. With the vent tube front or back, it doesn't sound to me like they would interchange, but maybe the vent hose can be twisted around. I don't know. I appreciate reading and learning from your posts and certainly didn't mean to contradict you. I bought a spectra brand tank made in Canada for mine, but wondered if you happened to know how the imported tanks compare in fit,finish, and quality? Sorry if I spread the wrong information.
Old 03-04-2010, 07:49 PM
81-F-150-Explorer 81-F-150-Explorer is offline
81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold81-F-150-Explorer is a splendid one to behold
It's nice to have evap emissions for one purpose only. It keeps more gas in your tank instead of it vaporizing to the atmosphere as the evap system vents the tank in a closed system through the charcoal canister.
A truck without evap emissions vents the tank through the gas cap.
Make sure you switch the gas cap for a truck without evap emissions to match the non-evap tank, that way you shouldnt have any problems. (State emissions testing notwithstanding etc...)
If you put a evap-emission gas cap on a non-evap tank, it can severly pressurize the tank. Spewing gas, vapor locking, even tank ruptures etc...
So evap-emission gas cap with evap-emission gas tank...
...and non-evap-emission gas cap with a non-evap-emission gas tank.
Hope this helps...
Old 03-04-2010, 09:01 PM
spudgunman's Avatar
yes that helps I likely have the wrong cap right now...
I dont have any charcoal tank in the truck so I will just buy with none and get the right gas cap.
Old 09-07-2011, 10:34 AM
Thiat302 Thiat302 is offline
Thiat302 is starting off with a positive reputation.
Just to be sure before I click Order- if i have a tank with a hose come from the middle front and going along the right side frame rail, I do have the tank with the extra hole in the top?
I dont want to order the wrong one and I believe Im correct but could someone just "sure" things up for me?
Old 09-07-2011, 01:50 PM
Evaporative Emission: Has hole(s) in the top of the tank(s) for the fuel vapor valve(s). Hose(s) route from the vapor valve(s) along the passenger side frame rail to the charcoal cannister.
1977 F100: The cannister is plastic, rectangular in shape, mounts adjacent to the alternator on the frame rail.
The fuel cap is non vented, and, as original, had "4 ears" on it. This cap and the filler tube(s) had a restrictor that only gas station nozzles for unleaded fuel would fit into. Leaded fuel nozzles were larger, today all are the same size.
Some peeps knocked out the restrictors, changed to vented fuel caps, so they could run leaded fuel (which was cheaper), but many were unaware that...
The lead in the fuel melted the charcoal in the catalytic converter...pushing it into the muffler. It wasn't long before their vehlcles sounded like vacuum cleaners headin' on down the road.
Peeps either removed the catalytic converter, or gutted it by removing the charcoal...all of which was illegal...and still is...in some states, CA...for example.
gas tank replacement question forango 1973 - 1979 F-100 & Larger F-Series Trucks 7 04-06-2016 06:57 PM
Eec tank conversion maytea 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-12-2015 07:12 PM
How to setup EEC gas tank system? Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 6 05-20-2011 09:53 AM
Does 1993 F150 have EEC-IV? mike L 1987 - 1996 F150 & Larger F-Series Trucks 2 01-23-2010 11:08 AM
EEC in 85 Ford Bronco ragingwildbill 1978 - 1996 Big Bronco 8 02-04-2001 05:44 PM
Tags
1970s, 1997, canister, cannister, charcoal, eec, ford, gas, grand, marquis, tank, tanks, troubleshooting, truck, tucsonaz, vapor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
