Go Back   Ford Truck Enthusiasts Forums > Diesel > 1994.5 - 1997 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 03-03-2010, 06:08 PM
enosez enosez is offline
1994 Ford F-250
enosez is starting off with a positive reputation.
1994 ford 7.3l turbo diesel
I tried to post in the classified section but it wouldnt let me.
Anyway, does anybody know what a 7.3l turbo diesel is worth out of a 94 f-250 with about 140k miles. Starts,runs and drives but does blow some smoke.
Anyone interested??????
  #2 (permalink)
Old 03-03-2010, 06:23 PM
JamesHajek's Avatar
JamesHajek JamesHajek is offline
Garage is empty, add now
JamesHajek is gaining momentum as a positive member of FTE.JamesHajek is gaining momentum as a positive member of FTE.
Just the engine or the whole rig? Is it a powerstroke or an IDI?
__________________
James
95 F-250 4x4 Automatic, Autometer gauges, 4" duals, Full Force Stage 1's
00 F-350 4x4 ZF6
  #3 (permalink)
Old 03-04-2010, 06:16 AM
1994 Ford F-250
Just the engine. Its still in the truck so I can still demo it.
I think its a powerstroke.
  #4 (permalink)
Old 03-04-2010, 12:24 PM
JamesHajek's Avatar
Depending on how clean and pretty you make it, Ive seen some powerstroke engines on craigslist anywhere from $500-1500. So Im not sure if this will help you but just trying to give you an idea.
__________________
James
00 F-350 4x4 ZF6
  #5 (permalink)
Old 03-05-2010, 10:01 AM
1994 Ford F-250
Vin K
Its a Vin K.
Cant find anywhere if thats a powerstroke, IDI or just plain turbo diesel.
I do know this engine was only offered in 94 which leads me to believe its just a turbo diesel.
But anybody know for sure?????
Its also got 250k miles on it...
  #6 (permalink)
Old 03-05-2010, 11:22 AM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.
If it has a auto trans it's a IDI... manual should be Powerstroke
__________________
Brownie (Evan) Ooh-Rah! Once a Marine Always a Marine Oregon Chapter Member
'95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears
'10 Escape, 200hp 3.0 V6, 4x4 - Stock
  #7 (permalink)
Old 03-05-2010, 02:59 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Lift the hood and look at the engine. Can you see the hard lines running from the injector pump at the front of the engine to the fuel injectors (four on each head)? If you can see the injectors it is an IDI and not a Power Stroke.
  #8 (permalink)
Old 03-05-2010, 08:01 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
1997 Ford F-350
My Garage
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
VIN K is an IDI 7.3 turbo.
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #9 (permalink)
Old 03-05-2010, 09:45 PM
scatgo's Avatar
scatgo scatgo is offline
scatgo is gaining momentum as a positive member of FTE.
Quote:
Yep, gota be. I have a late 94 di powerstroke and its a F motor.
__________________
1994 F350 CC Dually
7.3 DI TURBO DIESEL
5 SPEED
HPX, FPR shimmed, Edge
Intake, Downpipe, Cat delet
Tags
1994, 1997, 73l, 94, code, diesel, f250, f350, ford, forum1994, forums, paint, specs, turbo, turbos
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
