Rebuilt 460 /C-6 Near Savannah
Category: Engine - Complete Motors
Price: $1350
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): '92+ Civic/EL & Del Sol, '06+ Civic/CSX, Prelude, Fit, S2000
Item Condition: SC
Engine: Part suitable for gas truck
I am selling it because I have changed my plans for the truck, and will do a frame-off resto over the next year, then put either a 4.6 or a diesel in it.
You can test drive this truck now, and I will pull this engine after you test drive it (with a deposit).
I am asking $1350 or best offer.
Here is the description:
'86 460 with '86 heads
Cloyes double roller cam gears
RV cam for low end power
Edelbrock Performer intake
Edelbrock 1470 750 CFM carb on a 1" phenolic spacer with Ford linkage
Duraspark II ignition - complete wiring system can go with the engine
Performance aftermarket manifolds with copper gaskets and 3 inch dual exhaust
Serpentine belt system
Automatic C-6 from an '83 F-350 fifth wheeler, including cooler lines; has the extra clutch packs and heavy duty internals
Rear sump oil pan, with performance oil pump, pickup tube and dipstick
Includes alternator, starter, water pump, fan clutch with 7-blade fan, A/C compressor (may need replacing?), external oil cooler, air cleaner, transmission output shaft/yoke and a few misc spare parts.
Negotiable:
The complete exhaust system, which will fit Ford trucks '65 - '79
Engine mounts/perches, which are Ford factory for 429/460, and fit Ford trucks '65 - '79
Includes everything from top to bottom, front to rear except:
Radiator
PS pump - I have a usable core if wanted.
Hi Triplecreek - I am not sure what you mean by "clean" - do you mean shiny and painted?
Everything was rebuilt in 2005, and I have just used the truck as an emergency or second vehicle, so it has few miles on it, but it is not a show engine or transmission.
It is a power monster too!
I am interested in trading for a running '87 - '92 F-250 with a 6.9 or 7.3 IDI diesel.
