Head Gasket Replacement Cost? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-03-2010, 11:08 AM
99F250Iowa 99F250Iowa is offline
99F250Iowa is starting off with a positive reputation.
Ok, so my head gaskets have the famous leak. Drivers said worse than passenger. Not leaking bad but I want to get it fixed. My uncle knows how to do it all but is pressed for time sometimes. So, I found this guy that's a mechanic that is looking for side projects. He got back to me with a price.... for the gaskets, fluids, timing chain, labor, etc.. he quoted me about $3500 bucks? Ok, so he tells me he does the work for much cheaper than any shop would do it then sends me this quote. I could probably take it to Ford and get it done cheaper than this. I'm gonna work on it with my uncle over the summer. Start tearing it down in my garage and work on it when we have time since I wont need the truck much and save a ton of money. But is $3500 bucks rediculous?
Old 03-03-2010, 01:12 PM
cworley250sd cworley250sd is offline
cworley250sd is starting off with a positive reputation.
What size motor, gas or diesel?
Old 03-03-2010, 01:37 PM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.
That sounds high for a gas engine, about right for a 7.3, or cheap for a 6.0 or 6.4.
Old 03-03-2010, 03:09 PM
FI460's Avatar
FI460 FI460 is offline
FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.FI460 has a great reputation on FTE.
I was quoted from $2200-$3600 by the three local dealerships for just the headgasket on a 6l.
Old 03-03-2010, 04:04 PM
Boostcrazy99's Avatar
Boostcrazy99 Boostcrazy99 is offline
Boostcrazy99 is gaining momentum as a positive member of FTE.
If you are talking about a 5.4L, one head gasket is about $1,300-$1,500 (Ford). If it's both then $2,000-$2,200 max. I just replaced both heads on a 5.4L. My cost for new heads, gaskets, timing chain set, spark plug, head bolts, oil and filter was under $1,500. Might want to look into replacing the heads while they are off to get the better spark plug threads. Just some food for thought. Without the heads you are looking about $500-$650. Hope this helps.
Old 03-03-2010, 05:29 PM
While I have the heads off I might look into a repair kit for the plugs. I can't afford to replace the heads. That's why I'm going to do it myself instead of taking it somewhere. I have all summber and fall to get it done. So if it stays taken apart for months it's no big deal. I can't afford to dump a couple grand in it. Yes it's the 5.4 motor. No way would I pay this guy that amount of money. He even told me he had some connections since he is a mechanic and can get deals on parts. I know the parts manager at the local fordtown here and I can get stuff at cost. So he definately didn't get me any deals. I'm gonna call Fordtown and ask them how much they would charge and email this guy back and say look dude... I can get it done cheaper at the dealer so what kinda crap are you giving me.
Old 03-03-2010, 06:30 PM
Toreador_Diesel's Avatar
Toreador_Diesel Toreador_Diesel is offline
Toreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputationToreador_Diesel has a superb reputation
$3500 for a 5.4 motor?!?!?
What the hell was that guy smoking?
If it were a 6.0 with new heads, new gastkets, ARP studs, and an EGR delete that would make a little more sense, but still would be a little overkill...
The timesert job is much easier with the heads off. Haven't had to do it for anyone, but it looks much easier with the heads off.
Old 03-03-2010, 07:30 PM
Monster-4's Avatar
Monster-4 Monster-4 is offline
Monster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud ofMonster-4 has much to be proud of
For $3500 you could drop in a 5.4 reman long block. That's way overboard from just head gaskets.
Old 03-03-2010, 07:51 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.BobbyDiesel71 has a very good reputation on FTE.
where in Iowa?
Old 03-04-2010, 11:24 AM
Im in Cedar Rapids BobbyDiesel. I knew the price he gave me was way overkill. I couldn't believe it. Another mechanic friend of mine said he would do it for about 800 bucks plus parts. Which is still more than I wanna pay. My uncle will help me do it for beer So it looks like I'll be doing it with him and saving a bunch. Where do you suggest getting parts from? Should I get Ford parts or something else? I know Ford has the redesigned gaskets, but I believe Felpro makes a good gasket also. Should I get new head bolts from Ford or get ARP? Trying to keep the budget to a minimum but still want good parts. What about timing chain?
Old 03-04-2010, 11:58 AM
Quote:
I get my parts from Rockauto.com. Way cheaper than any local auto part store. All the parts to do the job from Rockauto is about $440. I have a coupon code you can use if you go that route that will save you about $20. You will need new head bolts because they are torque to yeild bolts.
Old 03-04-2010, 04:46 PM
Lubbockguy1979's Avatar
Lubbockguy1979 Lubbockguy1979 is online now
Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.Lubbockguy1979 has a good reputation on FTE.
I'd get the black mls gaskets for the heads. Better sealing material. The bolts are not normally a issue on the gassers so stock replacements would save you some $$
Old 03-04-2010, 06:05 PM
Monster-4's Avatar
Fel-Pro makes a complete "rebuild" kit that has all the seals in one kit. Looks like RockAuto has it for $155. You'll still need head bolts.
Redundant ? for 2004 F-250 6.0L 4X4 Lariat fordigitty 6.0L Power Stroke Diesel 27 11-24-2014 10:52 PM
Oil in my 1997 f-150 5.4 coolant HARDCARVINGSKIER 1997 - 2003 F150 5 09-13-2012 01:07 AM
" Ford's aren't known for their reliability" guthrie&co 1999 - 2003 7.3L Power Stroke Diesel 41 08-12-2011 04:21 AM
Big new merged blowing head gasket thing thread kizzo 6.0L Power Stroke Diesel 88 01-13-2006 07:51 PM
Gudiance on a "Non Ford" Project 86moneypit General Automotive Discussion 7 06-19-2005 11:03 AM
Tags
2002, 2003, 73, cost, diesel, f150, f350, ford, gasket, head, headgaskets, job, replacement, time, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
