Dually Tire rotation - Ford Truck Enthusiasts Forums
Old 03-03-2010, 09:14 AM
bama29fan's Avatar
bama29fan bama29fan is offline
bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.bama29fan has a very good reputation on FTE.
What does everyone do for rotating tires on a dually? Im coming up on 6000 miles on my new set of tires and was wondering what is recommended
Old 03-03-2010, 09:19 AM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
I dont know. never though about it on a dually.
Old 03-03-2010, 09:38 AM
ltl_jrw's Avatar
ltl_jrw ltl_jrw is offline
ltl_jrw is starting off with a positive reputation.
I don't know about your truck but mine has polished wheels all the way around and up front that are only polished on the side facing out but not polished on the inside. In order to rotate my tires I would have to dismount the tires in order to rotate them sooooooooooooo I don't, not wanting to take the chance of dinging the wheels. I just keep a eye on the tires.
Old 03-03-2010, 09:40 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
I got 80,000 miles out of my last set of Michelin tires. I rotated them once, front to rear, then just switched them from side to side once. You have to break down the tires to rotate them because we have front only and rear only wheels.
Old 03-03-2010, 09:41 AM
bama29fan's Avatar
Quote:
how/ where did you rotate the inside rears ?
Old 03-03-2010, 09:43 AM
Quote:
I rotated the inside rear to the front because they don't wear as fast as the outside tires.
Old 03-03-2010, 09:51 AM
guitarpicr's Avatar
guitarpicr guitarpicr is offline
guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.guitarpicr has a very good reputation on FTE.
I was just reading my manual that came w the truck, mines not a dually but I noticed it said for duallys only rotate the front 2. If u have the manual that came w the truck check in there to make sure.
Old 03-03-2010, 09:56 AM
Calli's Avatar
Calli Calli is offline
Calli is starting off with a positive reputation.
As stated above, Quote from owners manual "If your vehicle is equipped with dual rear wheels, it is recommended that only the front wheels be rotated (side to side)."
Old 03-03-2010, 10:01 AM
Quote:
You are right about the rotation of the tires on a dually. Thats why I started switching them side to side. Here is the owners manual. LINK
Old 03-03-2010, 10:21 AM
bama29fan's Avatar
cant open link...
so you just rotate the fronts side to side and then since they will wear much faster than the rear you just replace them? or would you then move one of the sets of rear to the front and put the new ones on the rear?
and if your just rotating fronts side to side why even bother unless you start seeing uneven wear on each tire?
Old 03-03-2010, 10:26 AM
I just switch them from side to side. The tires will be turning the other direction when they are switched like that. I will only do this when I have the tires off for what ever reason. Most don't ever rotate a dually.
Old 03-03-2010, 10:31 AM
bama29fan's Avatar
Hmmm...
how many miles are you getting out of the fronts? compared to the rears?
i have 10 ply toyo's not sure which model tho...i think it's something like Open Country. I'll have to check at lunch
Old 03-03-2010, 10:35 AM
I got 80,000 miles on my last set of Michelin tires front and rear. In fact, I gave my 4 rear tires to my employee at the time to put on the back of his truck. I only have highway miles on my tires, never go offroad. I also run 80 psi in the rear tires and 70 psi in the front tires at all times.
Old 03-03-2010, 01:29 PM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
I have 6 alloy wheels, and yes there is a front vs rear wheel. 4 of my wheels are factory fronts. Having said that, here is my rotation.
I start with drivers side rear. All tires continue in same directions.
1) Outside driver to front passenger
2) Front passenger to inside passenger
3) Inside passenger to driver outside
4) Outside passenger to front driver
5) Front driver to inside driver
6) Inside driver to passenger outside
I do this at oil changes when all tires are the same.
Old 03-03-2010, 01:53 PM
bama29fan's Avatar
My head is swimming trying to envision this Makes sense tho...how did you come up with this?
Tire rotation titanminator 1999 - 2003 7.3L Power Stroke Diesel 1 04-30-2011 08:48 AM
Rotating tires on 2003 F350 dually dani9678 1999 to 2016 Super Duty 15 05-11-2005 07:45 AM
Dually tire rotation Habitat 1999 to 2016 Super Duty 8 08-06-2003 11:24 AM
How do you rotate tires on a dually ? Big Dually 1999 to 2016 Super Duty 5 04-25-2003 10:17 PM
Tire rotation on duallys Folly5678 1999 to 2016 Super Duty 13 03-26-2002 08:53 PM
Tags
06, cupping, dually, dualy, duelie, dullay, f350, ford, powerstroke, radial, rotate, rotating, rotation, tire, tires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
