Go Back   Ford Truck Enthusiasts Forums > Misc. > Air Intakes, Air Filters & Ram Air
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-02-2010, 09:01 PM
fordx316's Avatar
fordx316 fordx316 is offline
1988 Ford F-250
fordx316 is starting off with a positive reputation.
5.8 351w air intake.
Why does the 5.8 351 v8 have two tubes coming from the engine to air box? Can i conjoin them into one tube with one cone filter, or should i just add two air filters to each tube?Click the image to open in full size.
  #2 (permalink)
Old 03-03-2010, 12:24 PM
Beechkid Beechkid is offline
Garage is empty, add now
Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.Beechkid has a great reputation on FTE.
You can certainly combine them into one tube. However, the oem system is acutally very efficient & capable of support well over 460 cid up to 400 hp- especially with a filter change.
If you do an online search for “air filter test” there is a lot of very good information. IMHO, the CAI units are NOT WORTH THE $$! Unless you are talking about a system that was specifically designed for a specific application there are very little hp/tq gains actually achieved in a street use vehicle and there are very few docs that these mfg’s can produce that actually show an increase in hp/tq in the power-band range of a relatively stock street vehicle.
I would avoid oil impregnated filters. While they have their purpose in off-road applications, Ford/GM/Dodge all have “watch-out” bulletins where the oil has contaminated intake sensors. - they even have a training video for the tech's on this (flatratetech.com) .
If you look at the flow data, WIX HP filters flow 98+% of K&N and have a much smoother flow post filter plus excellent filtering, for a fraction of the price!
You can use a WIX OEM HP replacement filter in the OEM plastic manifold box or build an true air ram type intake into intake.
__________________
Member: Never trust a person over 40 who drives a Chevy club
Flatheads ain't so bad!
Certified backyard mechanic I & II
  #3 (permalink)
Old 03-03-2010, 07:42 PM
fordx316's Avatar
1988 Ford F-250
ooo. lots of help, thanks. idk what ill end up doing yet.
  #4 (permalink)
Old 05-11-2010, 05:50 PM
fluffykins's Avatar
fluffykins fluffykins is offline
fluffykins is starting off with a positive reputation.
i like the air horns(:
  #5 (permalink)
Old 05-11-2010, 09:21 PM
fordx316's Avatar
1988 Ford F-250
lol thanks, theyre loud and cool. a must have in ford trucks IMO
  #6 (permalink)
Old 05-12-2010, 03:23 AM
fluffykins's Avatar
were did you put the air compressor?
  #7 (permalink)
Old 05-12-2010, 08:28 PM
fordx316's Avatar
1988 Ford F-250
compressor is under the windsheild washer fluid, theres a hole down there a good size to mount stuff, and the tank is mounted underneath next to the frame rail right around the transfer case. It makes it easy to tap into the air tank so i can fill up my tires and stuff with the air.
  #8 (permalink)
Old 05-12-2010, 09:36 PM
fluffykins's Avatar
that would be good for air up tires after im done driving in the dunes. what kit did you use and were did you get it?
  #9 (permalink)
Old 02-09-2011, 10:27 PM
92freebee 92freebee is offline
92freebee is starting off with a positive reputation.
Beechkid, are the WIX HP filters you speak of a product like the fram airhog or just the standard WIX paper filter?
  #10 (permalink)
Old 02-10-2011, 12:44 PM
Quote:
Wix use to make an "HP" version of the filters (used in NASCAR, etc) but I have not seen those specific listings for a while and over the past few years, the "standard" paper elements I use in my vehicles have literally the same design similarities as the HP series, bu the flow test were done on the standard filters and HP versions.
__________________
  #11 (permalink)
Old 02-10-2011, 12:54 PM
I may have to order up a standard wix filter and compare it to the Auto-Extra filter I'm using now.
Tags
1988, 351w, 4x4, 58, 98, air, dose, f250, filter, flow, ford, intake, oil, system, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
