302/5.0 parts interchange
Old 03-02-2010, 06:48 PM
cookieman69's Avatar
cookieman69
cookieman69 is offline
I have 1986 5.0 ho it was rebuilt without roller cam I want to make it a carb motor I found a 302 carb motor but owner dosen't know what year it is I need to know if intake, water pump pulleys etc, from any year 302 will fit my motor Thanks Mike
Old 03-02-2010, 06:54 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
BaronVonAutomatc is offline
Exterior parts other than the harmonic balancer and flywheel/flexplate (assuming it's a pre-1981 engine) should swap over with no worries.
Old 03-02-2010, 09:23 PM
Conanski's Avatar
Conanski
Conanski is offline
Yeah a 5.0 is a 302 so everything bolted to the shortblock(including heads) will interchange though you want to be mindfull of the balance difference before and after 1981 as the Baron mentioned, and that there can be differences in water pump rotation, accessory brackets and pulleys with engines from different vehicles. Block casting numbers are down on the side near the starter and while that won't tell you exactly when the motor was built it will tell you general things about it like it's balance weight.
Old 03-02-2010, 10:45 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
They are the same... a "302" just means it has 302 cubic inches, wich translated to liters is equal to 5 liters (that's why it's a 5.0).
Old 03-03-2010, 06:53 AM
cookieman69
Sounds like I will be useing parts from 302 what do I need to do to make sure balance is right on motor I see alot of refrences to the (Right) (balancer- damper0 on the post about 302 's
Mitchapalooza
10-02-2015 04:23 PM
mitchgordon96
12-23-2014 08:29 PM
79outlawf150
06-01-2010 07:42 PM
85f-150 5.0
05-25-2010 07:00 PM
joewaldner
34
07-17-2007 02:13 PM
Quick Reply: 302/5.0 parts interchange
