302/5.0 parts interchange - Ford Truck Enthusiasts Forums
Old 03-02-2010, 07:48 PM
cookieman69 cookieman69 is offline
cookieman69 is starting off with a positive reputation.
I have 1986 5.0 ho it was rebuilt without roller cam I want to make it a carb motor I found a 302 carb motor but owner dosen't know what year it is I need to know if intake, water pump pulleys etc, from any year 302 will fit my motor Thanks Mike
Old 03-02-2010, 07:54 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
Exterior parts other than the harmonic balancer and flywheel/flexplate (assuming it's a pre-1981 engine) should swap over with no worries.
Old 03-02-2010, 10:23 PM
Conanski's Avatar
Conanski Conanski is online now
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yeah a 5.0 is a 302 so everything bolted to the shortblock(including heads) will interchange though you want to be mindfull of the balance difference before and after 1981 as the Baron mentioned, and that there can be differences in water pump rotation, accessory brackets and pulleys with engines from different vehicles. Block casting numbers are down on the side near the starter and while that won't tell you exactly when the motor was built it will tell you general things about it like it's balance weight.
Old 03-02-2010, 11:45 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
They are the same... a "302" just means it has 302 cubic inches, wich translated to liters is equal to 5 liters (that's why it's a 5.0).
Old 03-03-2010, 07:53 AM
Sounds like I will be useing parts from 302 what do I need to do to make sure balance is right on motor I see alot of refrences to the (Right) (balancer- damper0 on the post about 302 's
ECU needed after EFI to Carb swap? Mitchapalooza 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 10-02-2015 05:23 PM
building a 302 mitchgordon96 1987 - 1996 F150 & Larger F-Series Trucks 1 12-23-2014 09:29 PM
1979 f150 302 2 bar carb diagram? 79outlawf150 1973 - 1979 F-100 & Larger F-Series Trucks 1 06-01-2010 08:42 PM
Best carb setup for my 302? 85f-150 5.0 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 05-25-2010 08:00 PM
302 efi to carb joewaldner Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 34 07-17-2007 03:13 PM
Tags
302, 351w, 50, 8796, balancer, difference, flywheel, ford, harmonic, interchange, parts, pulleys, pump, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
