Front wheel noise - Ford Truck Enthusiasts Forums
Front wheel noise
Old 03-02-2010, 05:50 PM
gringo gringo is offline
gringo is starting off with a positive reputation.
Front wheel noise
Just installed both lower ball joints on an 2005 F150 4x4. Now under part throttle load like when you just start an incline a metallic noise comes from the front wheel. Best way to describe would be something loose knocking around on the backing plate. If I accelerate it goes away, likewise if I decelerate. Tried applying the brake without letting off the go pedal and it did not stop. Could the vacuum operated hub be loosing vacuum and allowing the gear to come in contact? By the way this does NOT happen all the time. You never know when it will happen.
Thanks in advance.
Old 03-02-2010, 05:51 PM
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to beholdRyan50hrl is a splendid one to behold
yep...check and make sure you didn't either rip the vacuum line when you pulled the lower ball joints or make sure its seated right...
Old 03-02-2010, 08:53 PM
Yes sir, lines are good. Took it apart again...cleaned all surfaces put a thin film of grease on mating surfaces. Still makes this noise. I read some where to replace the o ring when ever the hub is disassembled but the actuator is a sealed unit. I can not believe this thing is so sensitive.
Everything You Wanted To Know About The IWE System...And Then Some xjcamaro89 2004 - 2008 F150 404 01-03-2017 01:59 PM
2005 F150 4x4 Noise/Troubleshooting nfazer 2004 - 2008 F150 4 12-07-2014 11:19 PM
2002 Mountaineer V8 AWD Clunk noise when slowing UFtroll Explorer, Sport Trac, Mountaineer & Aviator 3 03-09-2012 12:21 AM
Rattling noise whe accelarating between 35 and 60 santiago1978 2004 - 2008 F150 9 05-17-2010 12:22 PM
Hub Nut Waaay loose- fordff 1999 - 2003 7.3L Power Stroke Diesel 6 02-12-2010 03:07 PM
Tags
2005, 2006, 4x4, 54, acceleration, applied, brake, f150, ford, front, metallic, noise, stops, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
