Marker lights on 06 tow mirrors.
I wouldnt wanna get diff lookin mirrors lol as i do like the OEM ones alot. But i was wonderin if they have any after market LEDS or somthing that will fit in the stock housing or somthing.
BTW, hybrids taaaaaaste greattt. I gotta prius mirror stuck in my grille. and my truck dont seem to wanna let it go
You know seems like if the wiring & attachment for the LEDs inside the enclosure is simple. You could just remove the stock LEDs and install a small direct wire LED strip in its place,that is brighter or has more LEDs. Depending on how the stock LED is attached, you might can just glue the new LED in place. I think most LED voltage/amps specs are very low so I dont think that it would even be an issue. You know if I were you I would change the color to something that makes your truck look cool and unique. Oh yeah, I have some Autozone automotive LEDs at home that are individualized single units that are designed so that you can install them in a base of your choice, but they are not bright at all, but they may make some that are.
You could go with something like these.
LEDTrailerLights.com - Ford SuperDuty mirror LED Light / lens replacement
Well there you go, looks like that will work perfectly you get to upgrade LEDs & lenses while keeping OEM look, good link Downriver Thunder.
How to get them apart?
Hello,
I just bought a 03 King Ranch 350 PS. I want to do the upgrade because my drivers side lense must have been hit slightly. The running LEDs are like BARELY on like you have to cup your hand over them to see them at all. How do you get the OEM's off? Do they they pull out or are there hidden bolts somewhere inside the mirror? I have never taken one of these apart.
Thanks for the link and for your help.
Hello,
BTW, I have the Recon clears on mine, and while I'm not sure that they're any brighter, I do like the way they look with my chrome mirrors.
