Washer Fluid Leak
I know when mine was leaking it was where the hose came through the fire wall up by the passengers feet. From the looks of the corroded penny I found under the carpet it had been that way for a while. I guess that explains why I was filling the tank every couple of days. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
<o></o>
Pulled off the kick plate and side plate and reconnected it.
Hey folks - sure enough (FTE I LOVE YOU!) I looked under the second row floor plate at the passenger door (removed with prying action - used a snub nose bottle opener) and the channel for wiring, etc. is/was full of orange washer fluid. Further, there was a "wet stain / moisture evidence" on carpet towards front row passenger side. No connections (splice point) on fluid line seen at the second row. Lifted the passenger front/first row cover to find (wait for it … more fluid). Ok so I removed the kick and side panel for the passenger and peeled back the carpet (velcro holds the carpet in place near the kick plate) and began looking for the firewall culprit. FOUND IT! Ok, here's the issue I am having. I could not find the supply side line near the firewall. I did not have adequate light. So I am asking, "Where's the supply line?" I can't reach the wiper activator and look at the line at the same time! LOL And actually I don't want to add to the fluid all in the vehicle on top of what I am seeing. Ideas please?
Side note: A gent posted two pics that show the plumbing. This will be helpful to everyone. The hose appears to be more towards the fender rather than the firewall proper (in the photo). So I'll be looking there when
1) I get all the existing/standing moisture.
AND
2) I have more light to see the other end.
AND
