Any comments on John Woods Torqshift flush procedure?
I saw this on TDS forum. One of the forum members on TDS contacted John Woods and this is the procedure he gave to the forum member:
Drain transmission pan.
Remove pan and clean.
Clean magnet.
Replace transmission pan.
Fill with 12 quarts od Mercon SP even though you just drained about 8 quarts.
Remove external transmission filter canister and filter element.
Tap filter canister for external tap/drain hose attachment, replace canister WITHOUT filter, connect suitable drain hose and place other end of drain hose in catch container OR
Place large container under external transmission filter mount.
Start engine and idle intil trans warms up (about 10 minutes).
When trans-cooler thermostat opens, remaining old fluid in cooler and lines will flow to external filter mount and out. Extra Mercon SP in overfilled case will replace old fluid.
When fluid stops flowing from external oil filter mount or drain hose, stop engine.
Install new external filter element, replace filter canister OR
Remove drain hose from tapped canister, close tap, remove canister, install new filter, replace canister.
Add Mercon SP to proper level.
What do ya'll think (Techs and Mark K)?
Clean magnet.
Mark K. replied on TDS and commented that the thermostat will still interfere. I will post a link later.
It is even more of an issue than that, the thermostat restricts flow to 10% when under the 170*F. So for a period of time it is a "restricted bypass" filter.
Our coolant filters are bypass filters, but they flow all the time (unless they are plugged).
The flow to the coolers is restricted to 10% of normal when the thermostat is closed. The nominal thermostat temperature is 165°F, so I recommend having the trans at least 170°F.
The external filter sees 10% of the flow in the cooler line. So if the thermostat is closed the filter is seeing 1% of the normal cooler line flow.
In my opinion this procedure will work well ONLY if the trans is above 170°F the entire time. If it goes below that temp it will just mix the old and new fluids in the pan.
In a couple of my past trucks (both chevy's) I drilled a 1/8 inch hole in the torque converter, tapped it and put a plug in it. I was able to get 90% of the oil out by draining the torque converter and pan both. I'm sure I'm not the first to think of this so I assume their must be a problem with doing this on the 6 liter Ford. So why can't this be done?
Is it assumed that in park & at idle that gravity is draining only the cooler & lines & there is no pressure in the system to push out all the other oil?
There is pressure in park at idle speed.
So your saying put 12 qts of new oil in & not the 8 qts & all 12 qts of new oil is going to run out & be wasted?
I think I'm still missing something in the procedure.
Thanks.
