Go Back   Ford Truck Enthusiasts Forums > Diesel > 6.0L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.0L Power Stroke Diesel 2003 - 2007 F250, F350 pickup and F350+ Cab Chassis, 2003 - 2005 Excursion and 2003 - 2009 van SPONSORED BY:
  #1 (permalink)
Old 03-01-2010, 08:50 PM
motor-man's Avatar
motor-man motor-man is offline
2007 Ford F-250
motor-man is starting off with a positive reputation.
Speedo Acting Up...What's My Problem?
Hey guys.
So for about the past 3 weeks I have been putting up with my speedometer acting up. It will either...
1.) Not work what-so-ever.
2.) Try working but will be inacurate
3.) Work fine (20% of the time)
4.) Work fine, then stop working lets say at 80km/h and will stop. Next start up the truck will think that it is at zero (even though it's still at 80), so another 80km/h and it reads 160km/h.
Whats the problem here guys?
Thanks.
__________________
2007 f-250 6.0l 4x4.MBRP to 6'' black stack, 6'' Pro Comp, Icon 1'' TEI Spacer, 37x13.5x22 Trail Grapplers, XD Hoss Wheels, Clarion Head Unit, JBL Amp, Dual 10'' Kicker Subs, Dieselsite Coolant Filter, Autometer Fuel PSI gauge, SCT TSX w/ Elite IDP Gerhead TSD and QuickTricks Tunes, MTW Stage 2, Upfitter Switches, High Idle Mod, Precision SS Winter Front, 305/70R18 Pro Comp Xtreme M/Ts, Bushwacker Flares, ARP Studs, N-Fab steps, 4.56 gears + MAG diff covers, Traction bars...
  #2 (permalink)
Old 03-01-2010, 09:34 PM
jboczar jboczar is offline
Garage is empty, add now
jboczar has a good reputation on FTE.jboczar has a good reputation on FTE.
more than likely you need a replacement instrument cluster. You could have your vehicle scanned for codes but if it doesn't generate any codes for either the cluster or the abs module then the cluster is bad. Try ebay or maybe a reputable you junkyard, you don't want to buy one from the dealership, they are very expensive.
  #3 (permalink)
Old 03-01-2010, 09:48 PM
motor-man's Avatar
2007 Ford F-250
Quote:
Thanks. A little over a week ago my ABS light came on. The next day about halfway to the dealership the light went out. I went anyways to see if there were still codes and get them checked out. The tech said there was a code for the driver front ABS, and some kind of code that required some kind of new flash (not exactly sure). After he cleared the codes, the light has not come back on, but the speedo was still whacky.
__________________
  #4 (permalink)
Old 03-01-2010, 09:59 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
I have read that sometimes turning your lights on and disconnecting your batteries will correct the problem for a period of time. Might be worh a try while you look for good pricing on the parts.
__________________
Mark
06 F250 CC SB FX4 Lariat;ARP studs;OEM gaskets;Banks exhaust;DynaTrac Ball joints;Coolant filter;High-Idle mod;RACCCV6000;JimmiJammers;Ravelco;SynchroMax xfer case;Fumoto valve;Harpooned;CPOhighwayProducts toolbox;tracrac;Fox Weatherboots;Wet Okole Seat Covers;BriteBox;Re-flashed;Quadzilla Recon XZT Fuel Press;Blue FPR spring;DashDAQ;PHP FICM;RiffRaff boots;DCPower250A;PowerInverter;Rancho7000's;BPD EGR cooler;One-piece HPOP fitting;D-plugs&standpipes;BPD BilletWaterPump;SCT w/ Matts SRL+;ELC Ultra;DuraTracs
Tags
2003, 2005, 2006, 2007, 60, cluster, dosent, f250, ford, lariet, powerstroke, quit, speedometer, sticking, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
